Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 04-21-2017, 04:26 PM   #1
songsj
Drives: 2015 2SS/RS Summit White
Outside Ambient air temp reading
Have a 2015 2SS/RS 14 months old 4700 miles outside ambient air temp reading is stuck at 57 degrees. Is this a common problem and where is the sensor located? thanks.
songsj is offline   Reply With Quote
Old 04-21-2017, 05:17 PM   #2
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
Yes mine does it all the time. You can pull the HVAC fuse by the drivers side door. I think it was that one that reset mine. There is a tech service bulletin to reprogram it but i have not had mine done yet.
JD555 is offline   Reply With Quote
