Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 05-19-2016, 04:44 PM   #1
shadymaro
shadymaro's Avatar
Drives: 2011 Camaro 2SS Manual
Arrow CAN SOMEONE PLEASE TELL ME WHAT THIS NOISE IS?
I have a 2011 Camaro SS (6MT). I have been hearing wierd rattling sound coming from under the car. When I do a cold start, the car is jerkier with less power. But when it warms up, the car is smoother with more power and no rattle. I do not hear the rattling when I do a cold start. It happens only after it warms up and has been driven. It rattles at low rpms, and when I rev up the car. Here is the video of the noise.
https://youtu.be/rcBiFExFpig
EXTRA INFO:
Magnaflow Comp Exhaust System
Fresh Fluids
Stock Engine with CAI
Stock Tune
No Codes
2011 Chevrolet Camaro SS (6MT)
shadymaro is offline   Reply With Quote
Old 05-19-2016, 05:36 PM   #2
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
Hard to tell from the vid. It almost sounds like a belt, but if it's coming from underneath, it could be an exhaust rattle
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 05-19-2016, 05:38 PM   #3
shadymaro
shadymaro's Avatar
Sent from my SM-G930V using Tapatalk
Old 05-19-2016, 08:27 PM   #4
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Check the tunnel cross brace for contact with your exhaust. As far as less power and jerky, I notice my 11 is a bit jerky at very low speeds and load when it's cold. But once it gets going it's no problem.
JerTM is offline   Reply With Quote
Old 05-19-2016, 08:31 PM   #5
shadymaro
shadymaro's Avatar
I appreciate the advice! I went and ran some live data on my o2s and number 2 was acting up haha. Supposed to stay at .5v haha so it may or may not have something to do with the power. https://vimeo.com/167362790
Old 05-19-2016, 08:44 PM   #6
JerTM
JerTM's Avatar
Which sensor are you looking at? Only the upstream 02s will affect the way a car runs. On cold startup you car is in open loop which means it ignores input from them anyway and goes off a base value. Downstream O2s will only monitor the efficiency of the catalyst and in no way affect the fuel trims.
Old 05-19-2016, 08:46 PM   #7
shadymaro
shadymaro's Avatar
It was warm. So when the motor gets to temperature, the pcm starts? Holy s*** that's advanced haha.
Old 05-19-2016, 08:47 PM   #8
shadymaro
shadymaro's Avatar
Idk I guess it was downstream because it would change when I rev
Old 05-26-2016, 07:42 PM   #9
Magna_Flow
Magna_Flow's Avatar
Drives: 2015 ZL1
Sounds like an exhaust rattle. May want to take a look at crossbraces, heat shields, and anything else that comes close. When the car is warm, the exhaust pipes expand, and is sometimes just enough to come into contact with something else.
Magna_Flow is offline   Reply With Quote
5th gen, camaro, exhaust, noise, rattle
