02-15-2010, 09:35 AM | #15 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
02-15-2010, 12:46 PM | #16 | |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
It could be a trap speed happy track. I've been trapping 88 mph in the 1/8 when I trap 111 mph in the 1/4 mile. So I would assume one would need 89-90mph in the 1/8 mile to trap 113 mph. Based on his 86 mph trap speed in the 1/8 mile, he should be trapping around 109 -110 mph tops in the 1/4 mile. Last edited by SGOS252382; 02-15-2010 at 01:04 PM. |
02-15-2010, 12:49 PM | #17 |
Drives: 2SS/RS CGM LS3 Join Date: Aug 2009
02-15-2010, 12:49 PM | #18 | |
02-15-2010, 12:52 PM | #19 |
02-15-2010, 01:26 PM | #20 | |
02-15-2010, 01:34 PM | #21 |
i have draged once well three runs but once. with my tc and my best r/t was .140 slowest .368
02-15-2010, 03:11 PM | #22 |
02-15-2010, 05:12 PM | #23 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
02-15-2010, 06:13 PM | #24 |
Nice job for your first time, be patient, you'll get better.
02-15-2010, 07:05 PM | #25 |
as requested
Here is a pic of this run. I am on the right side **sorry pic is so big**
02-15-2010, 08:07 PM | #26 |
Drives: 2012 Mustang GT Join Date: May 2009
02-15-2010, 08:44 PM | #27 |
I have an auto 2ss/rs A6 w/ muffler delete. I will race you at C5Fest...Whatta ya say? Two rookies going down in the 1/4?
Update...Build in process, Forged Rods, Pistons and rings, Johnson Lifters, NOVI1500 ECS SC, 13lb boost or more, LS3 Conversion 114/228/241 COMP CAM, Frostbite 4 row Aluminum radiator, 6L80 built, Circle D 6L80 PRO SERIES MULTI 258MM 2D, Stock 3.45 gears, 1-7/8 American Racing Headers w/HF cat, X-Pipe, Lingenfelter dual fuel pump, E-85 flex sensor, ATI super damper pulley, Ported TB, 160 therm, Trans cooler, Pedder's sways/end links/sub frame bushings, BMR trailing arms & toe rods, Coil overs. HP/TQ pending
02-16-2010, 06:45 AM | #28 |
Drives: 1969 Pontiac Firebid Join Date: Aug 2009
The spinning off the line will actually make the MPH better without gaining in ET. The RT doesn't mean anything in the 1/4 mile for ET or MPH. Heads up racing, yes, then it matters.
Free HP Tuners Beginners Tuning Guide
Michigan Snowmobiler 1969 Firebird: 7.55@97.93 1/8 1.70 60 ft.[/COLOR] EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me |
Tags |
drag, race, track |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
The time has come - First test drive! | mjrchabot | 5th Gen Camaro SS LS LT General Discussions | 0 | 08-05-2009 08:33 PM |
First time Camaro owner, long time fan... needs advice | Kalden | Cosmetics and Lighting Modification Discussions | 3 | 07-12-2009 08:36 AM |
Long time tunring over | TJ91 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 10 | 06-19-2009 08:30 PM |
Time Is Right for a Sleek, Fast, New Camaro -WalletPop | camaro5 | 5th Gen Camaro SS LS LT General Discussions | 22 | 02-03-2009 05:41 PM |
My last day here for some time. | 13F20 | Off-topic Discussions | 52 | 09-24-2008 08:34 PM |
