03-04-2014, 02:09 PM | #1 |
Do you let your engine warm up?
Just curious about how many let your engines warm up before you drive her. Luckily i have a garage so i start her then go back in shave brush my teeth and go to work.When i leave work i start her and gently wipe her down from the days dust.I couldn't imagine just jumping in a car and driving right off.I generally don't put in gear til i see 147 degrees.If this has already been covered,sorry.I did a search and a page came up but nothing about warming up your engine.
03-04-2014, 02:14 PM | #2 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
garage here also. Maybe 30-45 seconds and drive easliy for 5 minutes. Modern cars for along time now can get away with that vs the old days
03-04-2014, 02:16 PM | #3 |
Under a Peterbilt
Drives: Rogue, Durango and Camaro Join Date: Jul 2009
^yup! I usually let mine idle for 1-2 minutes then drive easy till I hit the freeway 7 miles away
Sold-2006 Pontiac GTO
M6 1 of 475 353rwhp 353rwtq Sold-2000 Camaro SS A4 Hardtop #867 of 8913 1 of 103 Bright Rally Red Hardtop SS A4 in 2000 2011 Camaro 2SS/RS M6 By Berger #11BC21 |
03-04-2014, 02:17 PM | #4 |
Drives: 2014 SS Join Date: Jan 2014
Garage as well, usually will give it about 10min
2014 SS Stainless Works Headers w/ high flow cats, Stainless Works Retro Chambered Exhaust, Jannety Tune, Hurst short throw, APEX catch can, Tampa Tunning Throttle Body, APEX/Gen5 LED fogs, CAI Intake system, Diode Dynamics LED's, ACS T4 Splitter
03-04-2014, 02:19 PM | #5 |
depends if im in a hurry, then no. If i was in no rush then i will let it sit until the idle smoothes out then ill use it however i like.
03-04-2014, 02:33 PM | #6 |
Drives: 2011 Camaro SS/RS 2SS Join Date: Oct 2013
Garage.
On a hot summer day. A few minutes max. Drive easy for a few then all is fair. A nice cool fall day. Lets say 50 F. Between 5-10 minutes. Then again drive easy for a few. To me its more about warming all the aluminum that the motor is made of slowly dependent on ambient air temp. |
03-04-2014, 02:34 PM | #7 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2006
Idle about 30 seconds to build oil pressure and then drive it easy until all the temps are up to normal
03-04-2014, 02:35 PM | #8 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Garage I usually wait until the trans temp starts to get close to normal then it's game time.
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
03-04-2014, 02:38 PM | #9 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
The best thing for an engine is to get to operating temps under no more than a low load as soon as possible. You are not doing your engine any favors by letting it idle and warm up. Start you car, put it in gear, and drive in gently until it has reached operating temp. This is better for it than the long warm up at idle.
03-04-2014, 02:49 PM | #10 |
Well this is a frequently asked question and my answer is: I crank it up and let it run about a minute to get the oil flowing - then I drive it easy for two or three miles or so. Then she's ready to keep up with traffic. I never punch 'er up until the temp guage is at normal - summer or winter.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
03-04-2014, 02:51 PM | #11 |
Engineer of softness-ware
Drives: 2013 2LT RS Join Date: Aug 2013
I start it up, get in and drive gentle for about 5-10 mins, far as I know as long as you aren't gunning the engine and going 0-80 rapidly the car will be fine as it warms up. Certain fluids won't warm anyway until the car is moving as apposed to being idle.
03-04-2014, 02:52 PM | #12 |
Drives: 2017 Z06 / 2012 CTS Join Date: Jul 2013
Usually idle 1-2 mins, go easy for a little bit.
03-04-2014, 02:55 PM | #13 |
I'll start mine up and let it idle for 3-4 minutes then take off. However, I try not to run the engine past 2500 until the oil temps get to at least 180*. The coolant temp will rise fairly fast, but it's the oil temp that is most important IMO and it will take forever to get warmed up unless you drive it.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
03-04-2014, 02:57 PM | #14 |
Drives: Black 14 2SS/1LE/RS 14 Tundra Join Date: Dec 2013
Yupp, trans will warm slightly but diffs wont at all. Mines garaged so 1-2 minutes to let oil get flowing good then drive it easy till oil temps over 180. Then I get to do 20-40 spiritedly all 1.5 seconds of fun.
