dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 11-07-2013, 03:47 PM   #1
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
how accurate is the oil life % in the DIC
The sticker they put on your windshield with next recommended oil change says I should have done it today or at 10800 miles. Currently I'm at 11500 and DIC says I have 42% oil life left. This would be my 3rd oil change, past 2 times I had car serviced at dealership with the semi-synthetic. Should I change oil now or wait??
Jenner is offline   Reply With Quote
Old 11-07-2013, 03:52 PM   #2
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
The sticker reminder is a profit item.
You should trust your DIC.
upflying is offline   Reply With Quote
Old 11-07-2013, 03:56 PM   #3
motorhead
Old 11-07-2013, 03:57 PM   #4
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
I change my oil twice a year with Mobil-1 regardless of what that sticker
or my computer says. About every 6-8,000 miles.
myold88 is offline   Reply With Quote
Old 11-07-2013, 04:01 PM   #5
motorhead
For some people that may be okay for others not, depending on how much and how are they drive. The car is smarter than we are these days. That's why I go with the DIC.
Old 11-07-2013, 04:07 PM   #6
Austin45
The Logistician
Austin45's Avatar
Drives: 2012 LFX 45th Anniversary
Some engineers slaved over a complex algorithm to determine your oil life. I trust that over the sticker.
Austin45 is offline   Reply With Quote
Old 11-07-2013, 04:12 PM   #7
2xSSRS
2xSSRS's Avatar
Drives: 2017 SS Black on Black A8
I have 32k on mine and am only on my 3rd oil change. Follow what it tells you and save some money.
2xSSRS is offline   Reply With Quote
Old 11-07-2013, 04:12 PM   #8
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
Ok looks like the DIC is my best bet. Thanks guys and another Q. How low of a % do you let it get to? 20%?
Old 11-07-2013, 04:16 PM   #9
2xSSRS
2xSSRS's Avatar
I do it around the 5 to 6%. Get as many miles as I can out of it. It's expensive to change, as you know.
Old 11-07-2013, 04:28 PM   #10
DVader
DVader
DVader's Avatar
Drives: 2011 2SS/RS Vert
I change mine around the 10% mark. Just did the third change in 30,000 miles.
DVader is offline   Reply With Quote
Old 11-07-2013, 04:34 PM   #11
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
If the DIC is good enough for GM, it should be good enough for all of you as well!
As long as you're using a Dexos approved oil, trust your DIC.
BTW, anyone else LOL at all this "DIC" talk?
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 11-07-2013, 05:22 PM   #12
skibik
Guest
Drives: bbbbbb
I am at 9% when I checked the other day and around the 6k mark on this oil. I only have 14k on car and only changed twice so far. Dealer service department recommended 3k on first change and I used the DIC for the second and changed at 2% or 3% and had something like 5500 on that change. I use Mobil 1 and will changed it myself when it tells me to, 7500 miles or 12 months whichever comes first. I drive it daily for work through rain, sleet and snow. I only put on roughly 10k to 12k per year on a vehicle.
Dean.
skibik is offline   Reply With Quote
Old 11-07-2013, 05:28 PM   #13
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
I am different I change my oil every 5000 miles no matter what the did reads. I am not that trusting of electronic devices.
Caddy
Caddyroger is offline   Reply With Quote
Old 11-07-2013, 06:13 PM   #14
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
A lot of people change it way more often than needed, if that makes them feel better then I say go for it...it doesn't hurt anything but your wallet to change it more often, but it also doesn't hurt anything to follow the DIC monitor either... that's why it's there. If you follow it for oil changes you won't have any problems.
joeybsyc is offline   Reply With Quote
