01-19-2017, 08:07 PM | #15 |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
I just don't understand how the secondary cats have anything to do with throttle position but it sounds like you guys have experienced it.
Maybe Vitesse could shed some light on this. Sent from my SM-G920V using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
01-19-2017, 08:48 PM | #16 | |
Drives: 2017 camaro ss Join Date: Jan 2017
When you delete cats you create more airflow. At 50% throttle your ecu calculates a certain amount of air to pull and a certain amount of fuel. Because there is better flow, more air will be pulled with that effort and the ecu will actually think your at let's say 60% throttle instead, when your actually at 50. It doesn't become an issue until your at 100%, because when you give 100% throttle the ecu thinks your at 110% and it thinks that is impossible so it throws a code. The ecu has a built in learning curve to adapt to different altitudes. So that's why the throttle controller doesn't throw codes stock. But when you start modding things that slightly effect a/f ratio, it becomes an issue. |
01-19-2017, 09:03 PM | #17 | |
01-19-2017, 09:12 PM | #18 | |
My foot is now my throttle controller : ) |
01-19-2017, 09:18 PM | #19 |
Drives: 2018 1SS M6 Join Date: Nov 2014
Try recalibration, it should work. I think the mistake many make is that they do modifications, like a CAI, exhaust, PTB, and such, and don't think to recalibrate the controller.
01-19-2017, 09:45 PM | #20 |
Yeah you're right...recalibration works as long as it's within the stock learning curve. If it's too far out you're out of luck.
01-20-2017, 08:59 AM | #21 | |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
