01-18-2017, 01:15 PM | #1 |
Drives: 2017 Camaro SS 1LE Join Date: Nov 2015
Trying to figure out an issue
Last night my check engine light came on, said reduced engine power, and rev match stopped working even when turned on. There was also a red light on that was a P in a circle with a wrench under it which would have to do with the parking brake. The car will sometimes idle high as well around 1,000 RPMs. Only mods done to the car are rotofab that I put on recently and throttle controller that I've had on for months and thousands of miles. Anyone know what the issue could be?
Thanks
Show: C7 Carbon ZL1 Front Splitter/C7 Carbon ZL1 Side Skirts/Diode Dynamics LED Sidemarkers/Tinted Headlights, Fog Lights, and Rear Reflectors/20" Forgestar F14's in Bronze Burst
Go: 17" Forgestar F14s in Bronze Burst with Hoosier Drag Radials/Rotofab Intake w/ Dry Filter/EFI Flex Fuel Kit/Kooks 2" Longtubes with Offroad Connections/PRAY Performance Ported Intake Manifold/PRAY Performance Ported Throttle Body/PRAY Performance Ported Heads/PRAY Performance Tune Suspension: Phastek Lowering Springs/BMR Toe Rods/BMR Control Arms/BMR Trailing Arms/BMR Strut Tower Brace |
01-19-2017, 04:03 PM | #2 | |
Drives: 2017 camaro ss Join Date: Jan 2017
Unplug and replug in your controller and then drive it for 30 miles and a couple starts and stops. The code will clear. This issue will happen over and over again. |
01-19-2017, 04:27 PM | #3 | |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
01-19-2017, 04:38 PM | #4 | ||
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
This is the second thread he has mentioned deleted secondary cats and having problems but hasn't elaborated.
Could you have broken something or not fully connected something during the Rotofab install?
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
01-19-2017, 05:33 PM | #5 |
I'm 99% positive that nothing was broken on the rotofab install, going to re-adjust and tighten everything up again just to be sure. If it's the throttle controller could redoing the programming help fix it now that the rotofab is on, or will it not make a difference
01-19-2017, 05:40 PM | #6 |
Drives: 2016 2SS Join Date: Mar 2016
why don you quit guessing and find out what the code is. THAT is the starting point. geez, could be anything....
01-19-2017, 05:45 PM | #7 | |
Sent from my SM-G920V using Tapatalk
01-19-2017, 05:59 PM | #8 |
Deleting your secondary cats changes your airflow and throttle response a bit. As a result, your throttle controller causes your throttle position sensor to think there is too much juice going into your throttle. As a result, you'll get a throttle
Position voltage CEL. the same principle can be applied to your cai. The factory throttle position sensor has a range that it can be in without throwing codes. The vitesse at WOT pushes that boundary, and any other mods that effect throttle Response even slightly will cause issues. Especially on a higher setting on the throttle controller. I learned this from dealing with the issue myself. go read the code at an autozone and you'll see what I'm talking about. It has nothing to do with calibrating it. |
01-19-2017, 06:02 PM | #9 | |
01-19-2017, 06:03 PM | #10 | |
Position past the range. Like I said... the code will be throttle position voltage CEL. |
01-19-2017, 06:05 PM | #11 |
01-19-2017, 06:36 PM | #12 |
01-19-2017, 07:07 PM | #13 | |
Drives: 2016 Bright Yellow 2SS A8 Join Date: Jul 2014
In my experience this is true. I have the VTC. I went to an exhaust shop to have my secondary cats removed last year. First thing I did post install was to rev the engine to see how much louder it was over stock and got a CEL. It was related to the throttle positioning. I removed the VTC and drove home. When I got home I disconnected the battery overnight and reconnected in the morning. Reinstalled and reprogrammed the VTC and haven't had any issues since. I've done plenty of WOT runs and no more codes. |
01-19-2017, 07:38 PM | #14 | |
The other thing I noticed is that I only got the CEL in track mode. Tour and sport were fine because it had a less aggressive throttle setting in those modes. I finally got fed up and just had my tuner tune the throttle response to my liking. |
