Old 04-22-2012, 04:03 AM   #1
vafinest25
vafinest25's Avatar
Drives: 2010 2SS/RS "Orange Crush"
Brake Rotors
I am in the need of some break rotors, seeing as you can see the current ones I have really good with my Vossen CV-1 I have on now. The issue is that I am on a tight budget as I am purchasing the wife a X5. So I have allotted $500 for a set of four, I don't know if that is reasonable but either way I was hoping to get some slotted and drilled or dimpled ones. What's you guys thought or recommendations ?
I am here: http://tapatalk.com/map.php?cbqy5p
" When your ready to quite, your 1/2 way there"
" Drive It Like You Stole It "
[SIGPIC][/SIGPIC
vafinest25 is offline   Reply With Quote
Old 04-22-2012, 07:36 AM   #2
flyby
Drives: 2010 Silver SS
save more $500 will not get you 4 rotors.
flyby is offline   Reply With Quote
Old 04-22-2012, 08:38 AM   #3
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Try cleaning and/or painting. No reason to waste money on new ones...which after a season will look the same.
JimE is offline   Reply With Quote
Old 04-22-2012, 08:40 AM   #4
wirebender
wirebender's Avatar
Drives: 2017 ZL1, A10, White, sunroof, nav
I think it was Stillen in CA that had slotted WITH pads delivered for like $503!
wirebender is offline   Reply With Quote
Old 04-22-2012, 08:44 AM   #5
EXCALIBER
EXCALIBER's Avatar
Drives: 2010 2SS/RS.. her name is "Lucille"
Try E-Bay. I do alot of business with Brake Motive. They have the drilled/slotted rotors, and ceramic pads as a package deal. I have had very good luck with many different aplications of thier product.
EXCALIBER is offline   Reply With Quote
Old 04-22-2012, 09:20 AM   #6
Aldrich Z06
Aldrich Z06's Avatar
Drives: 02 z06,10 2SS/RS, 04 Duramax,11 335
I work at the BMW plant in S.C. and we build the X5, X6 and X3. What color did you get?
02 Z06
04 Duramax
14 335
69 Camaro
10 2SS/RS Camaro
Aldrich Z06 is offline   Reply With Quote
Old 04-22-2012, 09:28 AM   #7
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
Are the American made X5's sent to Germany?
upflying is offline   Reply With Quote
Old 04-22-2012, 09:30 AM   #8
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
I really like these.
http://brakeperformance.com/brake-ro...ake-Rotors.php
Mr_Draco is offline   Reply With Quote
Old 04-22-2012, 09:37 AM   #9
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Granattelli Motor sports sells a set of 4 for just under $500. You can get them from Summit Racing.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator.
7/1/09 Placed order for IOM/IO int/ SS/RS 6M
9/26/09 Took delivery!
v6sonoma is offline   Reply With Quote
Old 04-22-2012, 09:39 AM   #10
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I have brakeperformance rotors. They've worked well for me so far and they're reasonably priced.
Darth_Emma is offline   Reply With Quote
Old 04-22-2012, 09:41 AM   #11
Aldrich Z06
Yes, all X5s, X6s and X3s are built in S.C.
http://www.bmwusfactory.com/
02 Z06
04 Duramax
14 335
69 Camaro
10 2SS/RS Camaro
Old 04-22-2012, 09:44 AM   #12
oldfriend
Drives: Fiat 500 E
Easy fix , get the wife a X3 , done, no more problems .
oldfriend is offline   Reply With Quote
Old 04-22-2012, 09:57 AM   #13
1MULLET
Drives: 2002 2500 HD 9"lift, 2010 SS/RS
What he said.......I have thier products on 4 of my cars and will probably put them on the Camaro when I can.
1MULLET is offline   Reply With Quote
Old 04-22-2012, 11:11 AM   #14
Aldrich Z06
I used DBA rotors on a 69 Camaro I'm building.
02 Z06
04 Duramax
14 335
69 Camaro
10 2SS/RS Camaro
