08-28-2021, 11:05 PM | #1 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Get M Garage Oil Squirters - Anyone here tried them?
I’m going to give them a shot with my rebuild. Just ordered them from BTR. Wondering if anyone here has tried these? Seems like a slick product and way to add oil squirters to the LS3 block. The benefits for forced induction seems fairly well documented. ZL1’s use them. Must be something to it.
I substantially hurt my engine about 2 years ago. (Story is here: https://www.camaro5.com/forums/showthread.php?t=563071) Sadly, I’ve had it sitting in storage in my barn doing literally nothing. But I was busy with my 67 C10 project. Time to get the 2010 Camaro Kenne Bell back out (only has 14k miles) New parts going in: Callies Compstar Crank & Rods Diamond Pistons 4.070 (Staying stock cubes) 9.4:1 compression BTR PDS stage 3 torque cam Get M Garage Oil Squirters Johnson slow leak down lifters BTR shaft rocker kit Monster stage 3 clutch Parts going back on or staying on (old build) Kenne Bell 2.8 supercharger (was running 9.5 psi) Zl1 driveline conversion (3.73) LT Headers Other bits & pieces Looking forward to it. Should be a fun project and, hopefully, make some decent power when complete! |
08-29-2021, 04:06 AM | #2 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I thought the ls3 had oil squirters already?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
08-29-2021, 04:16 AM | #3 |
It don’t come easy.
I believe it’s the LSA that has the squirters.
08-29-2021, 04:29 AM | #4 |
08-29-2021, 06:54 AM | #5 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
LS3 = No oil squirter's. LSA, LS9 or pretty much anything boosted has the squirter's. They could also be referred as Piston Cooling Jets. They can be quite beneficial to any build, as they pull heat out of the pistons and combustion chamber. Stock compression, or non boosted engines dont see the cylinder temps needed to require them, so thats why they arent in the LS3 blocks. But if you're going high compression, or boosted, for sure use some or get the block machined to accept them.
08-29-2021, 10:56 PM | #6 | |
08-30-2021, 06:47 AM | #7 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
A lot of engine builders chose to delete the oil squiters for more oil flow to the heads. They dont come on lsx or dart blocks… food for thought.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
08-30-2021, 11:32 AM | #8 |
Drives: ZL1 Join Date: Dec 2016
Could that be because the LSX block is a iron block? I thought the dart block offered them. I know builders like Livernois and Hutter Performance recommend them on boosted engines, I do not believe the factory would just spend the additional money to add them if there was no benefit.
08-30-2021, 11:39 AM | #9 |
I think Thompson Motorsports doesn't like them and maybe even typically blocked them off on the their LSA builds.
https://www.camaro5.com/forums/showt...=588378&page=8 |
08-30-2021, 01:10 PM | #10 |
Whatever your opinion on them, they do in fact, pull heat out of the combustion chambers. Just because someone, a particular block or shop, doesn't use or like to use them is subjective. It all depends on your build and what you're trying to accomplish. If your running looser bearing clearances, and thicker oil, then I could see there being a potential oil flow / volume issue requiring an oil pump that cant flow enough volume to keep things lubricated. Especially if you have lifters with axel oiling thus exasperating the issue of oil flow. I all depends on what you're trying to do
08-30-2021, 02:13 PM | #11 | |
08-30-2021, 02:44 PM | #12 | |
Drives: it changes Join Date: Nov 2010
The OEM would be testing their engines at WOT for hours at a time Some also wrongly believe they can starve the main oil system of oil...which just doesn't really happen. If you're just doing a daily, fun car, drag race only...probably not a real benefit. If you're doing a lot of say 1/2 mile, mile, or long duration WOT ( say a boat or something ), then they are most definitely worth doing |
08-30-2021, 03:12 PM | #13 |
They potentially "can" pull too much heat from the pistons and cause issues with oil temps, and keeping that under control can be problematic. Especially if you used a block fill or half block fill. Everything is always a trade off. I see no real reason NOT to use them IMO, but to each their own.
08-30-2021, 03:20 PM | #14 | |
Certainly where they are easy to do, I'd be doing them. However....especially LSA/9 style...they do not like strokers. I've a 3.825" stroke on mine, and I can barely clear the squirters. Stock stroke would be no problem, 4" not a chance. Although mines an LS2 block drilled/tapped for the LSA/9 style. |
