Vararam
Old 02-07-2020, 09:50 PM   #1
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Intake scoop
What are your thoughts on the intake scoop. Seems like a great idea.... until it rains. Have debated on getting one as I know cold air/more air is better. Interested in everyone’s input on this.
Camaro2ss2010 is offline   Reply With Quote
Old 02-07-2020, 09:56 PM   #2
BAD DAB
BAD DAB's Avatar
I have one. Drove through several rain storms on my way to Camarofest with no issues.
Old 02-08-2020, 11:04 AM   #3
Coleroad
Coleroad's Avatar
Drives: 13 Camaro
It is not blowing water straight into your gilter by any means. The scoop is 17 inches from the bottom of my filter. There is no worries in my mind over it. I put a white box on the scoop so you could see it better in the picture.
Coleroad is offline   Reply With Quote
Old 02-08-2020, 12:09 PM   #4
judkins75
Silver Shark
judkins75's Avatar
Drives: 2014 2SS GM Npp 6 speed manual
I just had one installed, but haven't driven it in rain yet. I really feel like it's doing what it's supposed to do. Sucking in air..
Silver Shark20*10,20*11 Z28 black gloss replica wheels, 285/305 tires, BMR Strut brace,Kooks lt headers/hfc, CAI cold air intake/air scoop
judkins75 is offline   Reply With Quote
Old 02-08-2020, 12:38 PM   #5
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
It's not the rain itself you need to worry about, it is the puddles and flooded streets. I know this first hand. Any intake that is low mounted like this is something you have to be very careful about when driving in flooded areas. That is how I hydrolocked my L99 last year. Snapped a rod and demolished the piston skirt when my Vararam sucked up the wake my car made when trying to drive through water I thought was more shallow. 100% my fault.
So bottom line, if you are careful and use common sense any of these low mounted intakes and JRE scoop will be perfectly fine. The one that greenhornet showed us is probably even more safe than my Vararam as it has the front bumper and wheel well shielding it. The Vararam VR-SS has a huge scoop hanging down in front of the radiator.
I have not heard of any issues with the intake scoop as of yet. I have heard of issues with the Injen CAI on the V6 models though. I think that one actually relocates the filter pod very low.
InFiD3ViL is offline   Reply With Quote
Old 02-08-2020, 01:49 PM   #6
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
If you’re really concerned get an Ingen Hdydro Shield filter cover
https://injen.com/c-1389203-air-filt...ro-shield.html
camguynj is offline   Reply With Quote
Old 02-08-2020, 02:46 PM   #7
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
A little confused by a comment as someone seems to be implying the intake is lower compared to stock, it's not, it sits in the exact same spot as before having the scoop. FYI
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 02-08-2020, 02:56 PM   #8
Coleroad
Coleroad's Avatar
Drives: 13 Camaro
Exactly, and it’s not like the scoop runs up to the filter.
Old 02-08-2020, 05:47 PM   #9
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I used to DD my car in FL with a scoop. Zero issues. Summers it pours every day around 5pm.
I felt a difference after I installed the scoop.
CamaroDreams76 is online now   Reply With Quote
Old 02-08-2020, 11:38 PM   #10
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
I have one seems reasonable that you’d have colder air entering the motor. No problem with water here tho. I live in AZ and get 1 day a rain a year and my camaro is garaged. I’d say go for it, it’s cheap.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 02-09-2020, 07:35 AM   #11
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I would not worry. I have had mine on for years. It's just all about bringing the fresh cool air... when can that ever be bad. Water would not make its way up that high unless you submerged the car in a lake.
newagemuscle is offline   Reply With Quote
Old 02-09-2020, 07:39 AM   #12
newagemuscle
Philippians 4:13
Here is what mine looks like. This is the APEX. Not even sure they are in business anymore, but I know there were other options out there.
Click link below:
https://cdn3.volusion.com/ctar4.eg2j...che=1552557765
Old 02-10-2020, 06:52 AM   #13
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Apex is not in business anymore..... And yes I daily with the Cold Air Inductions and a scoop in Rainy Oregon, and back when they first came out a few people Hydro locked their engines with a stupid tube down toward the ground which really does not help due to the length and that was with the INJUN.....
ruining their engines down in sunny Cal which BTW does not have a good storm water system often anywhere down south so high water happens.... Being smart enough not to drive through it helps 100% And having a long long tube not good for performance either...… I also relocated the windshield washer bottle and it just more a pain to fill with the long tube having to be jiggled to vent air...
christianchevell is offline   Reply With Quote
Old 02-10-2020, 07:37 AM   #14
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
No worries with my scoop and CAI I try not to drive in the rain anyway but I have been caught a couple times, no issue at all. To get enough water to hydro lock an engine you would have to be driving through deep water and pretty much submerge the air filter, or fast enough through water deep enough to come in through the lower grill that it would shoot a ton of water up into the air filter.... Don't do that. Not a hard situation to avoid.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
