Old 03-10-2022, 09:56 AM   #1
hakank14
hakank14's Avatar
Drives: 2022 Camaro 2SS 1LE M6
Trans fluid for SS 1LE M6
Uggh, I know this has been beaten to death - but I am considering changing the transmission fluid at or around the 1500 mile mark. I'm convinced that the OEM tranny fluid sucks ass. Based on past reviews from other owners, I've pretty much narrowed it down to either the AMSOIL Signature Series ATF or the Redline D4 ATF. I use AMSOIL for the engine oil and am happy with it, so my initial lean is towards the AMSOIL - but I'm seeing a lot of Corvette owners are big on the Redline D4. I don't plan on tracking it much, I'm more concerned about smooth shifting for daily driving. Just interested in hearing which one is more preferred and why? Thanks!
hakank14 is offline   Reply With Quote
Old 03-10-2022, 10:08 AM   #2
ZPirate
ZPirate's Avatar
I've always had good experiences with Redline products. I use Redline oil, transmission fluid, differential fluid and power steering fluid in my 2003 350Z. I've had that car now for going on 20 years and been using Redline products in it for at least the last 10 years.
When it comes time to change the transmission and differential fluids in the 1LE I'll certainly look at Redline first. Of course both of my cars are manuals, not automatics.
2019 Dodge Durango R/T (daily driver)
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 03-10-2022, 10:10 AM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i used the oem stuff last year for first time was going to use the tremec stuff but its $$$
Old 03-10-2022, 11:21 AM   #4
hakank14
hakank14's Avatar
Meanwhile, if you actually go to the AMSOIL site and search by vehicle - AMSOIL Torque-Drive ATF is what is listed as the recommended tranny fluid for the LT1.
Old 03-10-2022, 11:26 AM   #5
BrandanK
Drives: 2021 Camaro SS 1LE
I have heard others speak very highly of Mobil 1 Synthetic LV ATF HP.
When I change mine here soon, that is what I'm going to use. My 1-2 shift is pretty stiff when the car is cold.
BrandanK is offline   Reply With Quote
Old 03-10-2022, 11:26 AM   #6
Jeb114
Jeb114's Avatar
Drives: 2021 300
Amsoil is a supplier of oil to Chevy most likely that's what is in the trans now.
Jeb114 is offline   Reply With Quote
Old 03-10-2022, 11:46 AM   #7
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
redline for me was hard to shift while car was cold, took a good warmup / quick drive for it to feel better, i ended up swapping back to OEM stuff, might try the amsoil here soon.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 03-10-2022, 12:06 PM   #8
nprario
nprario's Avatar
Drives: 2017 1ss 1le HBM
Yup, here as well. Fine once warmed up but a bit stiff and notchy when cold.
nprario is offline   Reply With Quote
Old 03-10-2022, 12:11 PM   #9
Baddawg53
Drives: 17 hyper blue 2SS M6
I use the redline in mine, no issues at all.
Baddawg53 is offline   Reply With Quote
Old 03-10-2022, 12:17 PM   #10
6spdhyperblue
Drives: 6th gen
Who has used that in the M6?
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 03-10-2022, 12:28 PM   #11
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
I used Amsoil, a much better shift feel over the stock fluid.
soloknight6 is offline   Reply With Quote
Old 03-10-2022, 01:54 PM   #12
hakank14
hakank14's Avatar
I stand corrected, the Signature Series and Torque-Drive are both listed for the LT1
Old 03-10-2022, 01:57 PM   #13
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
I tried redline and also found it notchier than OE until it gets nice and warm. I'm planning on OE or Tremec fluid next since I've heard good things about it.
https://www.tremec-store.com/product...smission-fluid
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 03-10-2022, 05:34 PM   #14
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
OEM sucks, sucks harder when it's cold. I've tried Mobil1, Redline D4 and Royal Purple Syncromax (all better than OEM) but the Syncromax is the smoothest shifting 1 - 2 and everywhere in between. You can get a six quart case on Amazon for under $100, takes just under four.
Warrior102 is offline   Reply With Quote
