Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 07-28-2011, 07:40 PM   #1
Forza
Drives: 2010 Camaro 2LT/RS CGM
Changing Rear Differential Fluid
I'm at 9,300 KM or 5,800 Miles and after changing my oil a few months back, I thought I would go ahead and change the rear differential fluid.
First off the fluid smells horrible, OMFG. I gagged so much, maybe my nose is sensitive, but this fluid, both old & new smell so bad.
I'm attaching some pictures for you all to see how simple it really is to change this fluid.
1. Put the rear tires up on jacks.
2. Loosen the top & bottom bolts with a socket wrench but leave the bolts in.
3. Use your fingers to remove the top/fill bolt.
4. Use your fingers to remove the bottom/empty bolt. Into a catch can of course.
5. Drain until empty.
6. Clean the bolts with a rag.
7. Tighten the bottom bolt back into place
8. I maneuvered the bottle of AC Delco 75W 90 and squeezed until the plastic bottle was empty.
9. Tighten the top bolt.
10. Clean your hands cause they smell like a$$.
Pretty simple process, about 30mins total and now I feel more proud of my car cause I did it myself & I saved a few dollars.
Forza is offline   Reply With Quote
Old 07-28-2011, 08:17 PM   #2
jtzako
Drives: 2010 IBM Camaro SS
Good write up.. Make sure you go do some figure-8 in a parking lot to work it in. Also, keep an ear out for noises. You may need to add friction modifier.
Also, use gloves, it isnt healthy to let that fluid get on your skin.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 07-28-2011, 08:19 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
+1
great write up though
Click to view my build thread
The Stig is offline   Reply With Quote
Old 07-28-2011, 08:23 PM   #4
Forza
What kind of noises? What would make noises?
Should I be concerned about my green skin right now?
Old 07-28-2011, 08:53 PM   #5
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
When you skin starts to glow in the dark and your fingers fall off it might be to late to worry.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-28-2011, 08:54 PM   #6
Synner
Drives: cars
The clutch plates can stick and make noise. If it does then you need to add limited slip friction modifier. The bottle will say if it includes friction modifier on it. If not then you need to add it.
Synner is offline   Reply With Quote
Old 07-28-2011, 09:07 PM   #7
Forza
Even for Automatic V6's?
Old 07-29-2011, 08:40 AM   #8
Nomad
Nomad's Avatar
Drives: '11 2SS/RS RJT M6
Nope. I don't think you have a limited slip differential. They are talking about issues with the LS on the SS.
BTW, excellent write up.
Vararam CAI, Elite Engineering Catch Can, Separate Clutch Fluid Reservoir, Ghost Armor Full Protection Package, Chromed Turn Signal Bulbs, RPI Stealth Splash Guards, Skip Shift Eliminator, Defenderworx Chrome Bowtie Inserts, Pfadt Trailing Arms, Camaro Decal Store CGM Hood Spears with "376ci" custom text, Billet Depot/Drake Underhood Polished Caps, CGM Lug Nut Decals, Pedders Front Radius Rod Inserts, JacFab Front License Plate Bracket
Nomad is offline   Reply With Quote
Old 07-29-2011, 09:03 AM   #9
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Additionally you may want to take the vehicle out and do a few low speed figure eights, first one direction and then the other to distribute the fluid up the half shafts.
Cheers
K
Moriartii is offline   Reply With Quote
Old 07-29-2011, 09:08 AM   #10
Forza
Thanks everyone, I'm glad you liked the write up.
I'll take the car out again this morning around the block a few times to get the fluid moving inside around the gears (or whatever is in there).
Old 07-29-2011, 10:26 AM   #11
Jimbabwe
Jimbabwe's Avatar
Drives: 2010 IBM 2SS/RS
Is it recommended to do this when the car is hot? Or is cold ok
Jimbabwe is offline   Reply With Quote
Old 07-29-2011, 10:44 AM   #12
Moriartii
Moriartii's Avatar
I would do this when the car is cold as you are working near the exhaust.
Cheers
K
Old 07-29-2011, 10:52 AM   #13
Forza
Cheers
K
Yea what Moriartii said, definitely when the car is cold.
While under my car I did find myself rubbing my forearms against the exhaust & other metal parts. You would burn your skin for sure.
Old 07-29-2011, 04:03 PM   #14
The Stig
The Stig's Avatar
Originally Posted by jpizzle007 View Post
you should be able to do it without jacking up the car. Its also best to have it level when you add it back in.
If you back it to the lip of your garage, the extra inch helps a lot and there is no need to jack it up.
Yep. That's how I did it.
Differential Fluid JackRabitSlims Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 7 07-14-2011 09:25 AM
Differential fluid on paint TC Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 3 05-05-2011 10:36 AM
L99 Click click click at the rear axle differential gear housing Goliath Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 01-12-2011 10:16 PM
changing tranny and rear end fluid on a m6 ls3 what all is needed? and what fluids? Jferrell88 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 2 05-18-2010 06:13 PM
Rear Differential fluid Mobil 1 or Royal Purple, and motor oil discussion. 2010 Bumblebee V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 52 05-08-2010 05:34 PM
