TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 05-05-2015, 12:25 PM   #29
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Originally Posted by DWALEX View Post
As I told you in the pm the biggest problem with this cluster is that it asks for IDs frames or it is not compatible with the modules of the 2010-11 or they don't have it, I was able to disactivate this functions in the cluster (EX: steering wheel, suspension, etc.) but it is also necessary to upgrade some modules, at the moment I only need to correct a DTC CODE "U0020"
this code is set up when fewer modules are detected on the bus before the cluster can learn the other modules IDs
I'll post more info later
I know, have you tried using a spy tool to find what is needed to move the frames around? this is one we like.
http://www.intrepidcs.com/VehicleSpy/
2SSRS@Gen5diy is offline   Reply With Quote
Old 05-05-2015, 01:23 PM   #30
DWALEX
DWALEX's Avatar
Drives: Currently 2016-2SS, Future ZL1/Z28
no yet. have you installed it in a car with mylink?
DWALEX is offline   Reply With Quote
Old 05-05-2015, 07:03 PM   #31
Yippee38
Yippee38's Avatar
Drives: '11 SGM 1LT/RS, '02 SOM Firehawk
Subbed.
Here's hoping some collaboration will get this thing working!
Yippee38
Yippee38 is offline   Reply With Quote
Old 05-08-2015, 08:51 PM   #32
DWALEX
DWALEX's Avatar
like we know, the 2010 doesn't have an electric power steering wheel, so I solved the SERVICE POWER STEERING warning, the stabilitrak/TCS and competitive driving mode has no issues
Old 05-11-2015, 01:47 AM   #33
zkattac
Drives: 2011 Synergy Green 2SS Camaro
So the only thing left to work on is the airbag warning?
Was it complicated to fix the previous issues?
zkattac is offline   Reply With Quote
Old 05-11-2015, 12:45 PM   #34
DWALEX
DWALEX's Avatar
no, I have still more work to do,
it's not as easy as I thought
Old 05-17-2015, 09:51 AM   #35
MGD
MGD's Avatar
Drives: 16 Camaro SS
Bought a 2015 cluster with color DIC and put it in my 2012 2LS, turned ignition on and started the car.
Everything is working except the miles showing dotted lines and two errors on the display.
One is Stabilitrack, the other is service power steering. Do you thing this can be programmed to work?
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 05-17-2015, 10:18 AM   #36
DWALEX
DWALEX's Avatar
Yes, i can help
Old 05-17-2015, 05:39 PM   #37
USCAMARO14
USCAMARO14's Avatar
Drives: 2LS 2014
Thumbs up
Keep us posted
USCAMARO14 is offline   Reply With Quote
Old 05-20-2015, 08:44 PM   #38
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Old 05-26-2015, 10:04 AM   #39
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
subbed!
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 05-26-2015, 10:22 AM   #40
MGD
MGD's Avatar
I should have mine back tomorrow from programming. Will let you know how it turns out. Hope it's working as it should.
Old 05-26-2015, 10:31 AM   #41
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
where did you buy the cluster with color DIC ?
I have a 2013 does anyone know if this is a Plug an Play option or does there need to be programming involved.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 05-26-2015, 11:39 AM   #42
MGD
MGD's Avatar
I bought mine on E-Bay, Part number is A2C82887401, here is a link to one.
http://www.ebay.com/itm/Camaro-SS-Sp...500a07&vxp=mtr.
You do need to have it programmed to your car. DWALEX can help you.
