05-20-2015, 01:30 AM | #71 | |
Drives: 2013 1LE Join Date: Feb 2012
There is also the task of tuning said transmission/engine combo. The V8/V6 options have a solid base to start from. The T4 does not.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013 |
05-20-2015, 07:01 AM | #72 |
Drives: 2008 G37 Join Date: May 2015
thanks for adding the pdf file! now I can read it better on my PC
05-20-2015, 08:04 AM | #73 |
Drives: Impala Join Date: May 2015
Glad they are going with the 8L45 in the 4 and 6. 1st gear is geared 4.62 since the engines aren't as powerful and it weighs 33lbs less than the 8L90.
05-20-2015, 09:23 AM | #74 |
Drives: 2013 Camaro 2LT/RS Join Date: Sep 2010
05-20-2015, 10:08 AM | #75 |
Drives: 2015 Dodge Challenger SRT 392 Join Date: Dec 2008
Thank You for posting this up!
05-20-2015, 10:22 AM | #76 |
Not sure what tuning would need to be made for a lower power motor and seeing how they do have turbo 4 prototypes, application issues are solved. Only hold ups would be production related.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
05-20-2015, 11:05 AM | #77 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Anyone know what gearing comes standard on the A8 in the V6 and V8 models? Being an A8, aren't the rear end gears higher than we are used to seeing?
On that same token, I wonder if they will offer performance gears ala some kind of performance package. I've not seen anything on that yet.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
05-20-2015, 11:28 AM | #78 | |
having FUN now 13.66@101
05-20-2015, 11:36 AM | #79 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Actually it says "Available performance Brembo disc brakes", maybe the standard LT brakes are also made by Brembo but are not performance brakes. That would make both statements correct.
The Bird is the word! |
05-20-2015, 11:44 AM | #80 |
Drives: 2010 Camaro RS Join Date: Aug 2009
FINALLY, a brochure with all the colors, options, and info! I couldn't find the info anywhere else
05-20-2015, 12:27 PM | #81 |
Drives: 2010 2SS ABM -Sold Join Date: Jun 2009
Looking at 2SS, RS, Hyper Blue, M6, Mag Suspension, Jet Black leather, polished silver wheels, and more options as they appear!
2016 Hyper Blue 2SS M6 White Interior Mag Ride NPP GFX
05-20-2015, 03:03 PM | #82 |
Drives: 2010 2SS Join Date: Sep 2012
3.73 in the ss! *squeal* im not sure how the other gear ratios will change the effectiveness of that over the gen5 1-6 gears tho. I find my gen5 is geared like crap for cruising in most speed limits too. 3.73 probly help that.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
05-20-2015, 03:49 PM | #83 |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
I don't think there is an RS package for the SS. It looks like the SS comes with all the RS stuff standard. If I got the Hyper Blue, I would get the polished silver wheels too. Good combo!
05-20-2015, 03:52 PM | #84 |
1SS, A8, MRC, Dual Mode Exhaust, Premium Sound, Blue Velvet Metallic, Black Wheels.
