dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 10-11-2010, 04:11 PM   #1
Fogey
Fogey's Avatar
Drives: 2011 2SS/RS A6, IOM
!st Oil change tomorrow - 1600 miles (questions)
What did the car come with from the factory?
What should I ask to have put in?
If going to Mobil 1 from stock, for example, do you need an engine flush?
Thanks
Fogey is offline   Reply With Quote
Old 10-11-2010, 04:18 PM   #2
KeepItGreasey
So It'll Go Down Easy
KeepItGreasey's Avatar
Drives: Camaro SS/RS
you should read your owner's manual
KeepItGreasey is offline   Reply With Quote
Old 10-11-2010, 04:21 PM   #3
2010IBMSS
2010IBMSS's Avatar
Drives: 2010 camaro SS RS
it should come with Mobil 1 from the factory. Just change the oil yourself, it is not hard at all. Hope that helps ya...
2010IBMSS is offline   Reply With Quote
Old 10-11-2010, 04:23 PM   #4
BAD DAB
BAD DAB's Avatar
The Camaro SS comes from the factory with Mobil 1. I don't think a flush is needed. Most people on the site think that Mobil 1 is good. If you are doing your own oil change make sure you have a oil pan that can hold more than 8 quarts. I learned this the hard way. lol
Old 10-11-2010, 04:31 PM   #5
68blk/yel396
68blk/yel396's Avatar
Drives: 2011 RJT 2SS/RS
Oil Change
Thanks
The car comes with Mobil produts and I used and recommend Mobil 1 Oil synthetic and Mobil 1 Filter, no engine flush required. I did mine myself. Wal-Mart sells the products at very good prices, or watch AutoZone and other parts houses as they put this stuff on sale frequently. I spend about $45.00 total plus my free labor for an 8 quart oil and filter change.
Good luck !!!
68blk/yel396 is offline   Reply With Quote
Old 10-12-2010, 09:13 PM   #6
patigerjet
patigerjet's Avatar
Drives: 2010 1SS LS3 blk/blk(OrangeStipe-X)
Good luck !!!
I wish I would have read this comment yesterday. I took my 1SS today for its 1st cherry oil change at 1588 miles to my local trusted oil/car wash place. I was thinking i was gonna put in regular oil in as I thought it was already in it and so I told the guys to put in conventional. Prior inquiries to my Chevy Dealer & a call to GM corporate for advice on my 1st oil had failed to tell me it has Mobil 1 in it already.
But to my shock today the oil tech man showed me the oil cap with the "Mobil 1" logo while he had it on the rack for the service. So of course not wanting to short change my beloved SS, I had them put in Mobil 1 (never would have thought Chevy would have put the M1 in, It must be a deal they made with them for the upfront promo)
Final Bill came out to $80 since they had to charge me for 3 extra quarts at $6.00/quart for a total of 8 quarts!!!
Leaned a lesson, next year, will be doing my own oil change from wherever I can get a good price for the M1. Could have saved almost $30 or so minus the filter. With the low miles I put on it (less then 1500 miles/year), the synthetic should last for a year without needing to be changed out.
patigerjet is offline   Reply With Quote
Old 10-12-2010, 09:34 PM   #7
SC2150
Drives: 2012 Camaro RS, RX supercharged
There is never a need to flush when switching from a conventional petroleum based oil to a synthetic with todays syn's. The blend readily. The motor already has had some break-in done right after assy, but still come w/M1. On the engines I build I break them in the first few hundred miles with a good petrolium based high zinc content oil and then switch to syn after that. I also use 2 stroke oil to coat the pistons/rings/cyl walls during assy as this seems to help the rings seat quicker w/out the residue of reg motor oil burning as the 2 stroke burns pretty clean.
SC2150 is offline   Reply With Quote
Old 10-13-2010, 09:11 AM   #8
Sword5
Sword5's Avatar
Drives: 2010 2SS
Just changed mine this past weekend. Wal-Mart had 5qt jugs of Mobil 1 on sale for 24 bucks I believe. Saved $10 a jug compared to price at local auto parts store. Once you get your car on jack or ramps takes about 20 minutes or so. Total price was roughly $59 with oil and filter. Like Jus1dab said make sure your oil pan draining into will hold more than 8 qts of oil. The 15 qt ones work great.
Ordered 6/19/09 Black on Black 2 SS Delivery 10/14/09! Added CAI, Heritage Grill, DRL Plug and Play Harness
Sword5 is offline   Reply With Quote
Old 10-18-2010, 05:33 PM   #9
Texhawk
Texhawk's Avatar
Drives: 69Camaro,87IROC,96 SS,Z06&Stingray
I am coming up on the first oil change for my 2011 model, and I am going with Valvoline Synpower so I can just keep one brand of oil in the garage for all my cars. I already switched from Mobil 1 on the Z06 since Valvoline has now surpassed Mobil 1 in wear protection.
Texhawk is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
OIL CHANGE 5500 MILES camaro4eva Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 19 11-18-2010 01:01 PM
Car "waking up" after oil change..is this due to the fuse pull? CamaroFemme 5th Gen Camaro SS LS LT General Discussions 6 10-05-2009 03:44 PM
Help - Oil change hasn't been done yet @ 4500 miles firstmate Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 13 08-30-2009 09:42 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
