07-10-2018, 10:42 PM | #1 |
THE Cone Killer
Drives: 2015 2SS/RS BVM; 2016 Vette Z51 Join Date: Jun 2013
Directions to CF8 from I 40 west coming from Knoxville.
Looking for the best route to get to CF VIII coming from I40 from Knoxville,
Is it best to go all the way to Nashville and north on 65 OR get off on one of the twisty curvy roads ? Thanks for responding.
ARH Full exhaust w/ HF cats
CAI Cold Air Intake w/ scoop, Gears 3.73 BMR 1.25 inch lowering springs, Trailing Arms, Toe Links, Cradle and offset Diff Bushings, Bilstein Struts, front and rear ZL1 rear Diffuser, Rocker Panels, 1LE Front Splitter Z28 High Wing Rear Spoiler, Tuned by DynoSteve |
07-10-2018, 11:32 PM | #2 |
Jan
Drives: 2010 Camaro 1LT Red Jewel tintcoat Join Date: May 2010
I guess it depends on if you want a fun drive or a quick one.
07-11-2018, 05:46 AM | #3 |
Drives: 2010 2SS/RS M6 SW Join Date: Mar 2010
I-40 West to Nashville, North on Briley Parkway and then north on I-65 to BG is the quickest way. Hwy 109 and Hwy 231 routes are a few miles shorter but not as quick.
TSP Stage 3 Cam, BBK SS/Ceramic Headers, Solo Cats, Borla Exhaust/Deletes, K&N CAI, Lethal Performance Tune, Carbotech Brakes, Phastek Braided Brake Lines, Brake Ducts, BMR/Eibach Springs, Hotchkis Sway Bars & End Links, BMR Chassis Connectors, Vorshlag Camber Plates, 1LE 3.91 Gear, Hurst Shifter, 2017 ZL1 Wheels, ZL1 Grille and Ground Effects, SLP Splitter, MPD1 Spoiler, Oracle Interior Lighting, Gen5DIY Headlight/Halo/DRL System
07-11-2018, 04:10 PM | #4 |
Garmin or Google will give you the best route. I use my Garmin.
07-11-2018, 08:50 PM | #5 |
Green Manalishi
Drives: 2010 Synergy Green Camaro LT Join Date: Sep 2014
When we came back from Pigeon Forge to Indiana Via BG, we went toward Lexington then cut over at London. Not sure of the time difference if you go that way.
07-11-2018, 10:10 PM | #6 |
Drives: '17 2SS 50th Join Date: Sep 2016
I drive to Knoxville almost every weekends from BG and whichever route you take, it doesn't make that much of a difference.
Always about 2:45 to 3:00 drive depending on traffic. On busier weekends, I recommend taking 231 as it seems to have less construction going on.
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
07-12-2018, 01:37 AM | #7 |
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
Im in knoxville now
Gotta make a run at deals gap and run the dragon Then pick up big. Jon amd head in to Bg |
