Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 03-14-2015, 02:10 AM   #43
Anna_Keyee
Drives: 2013 Ford Expedition
fyi, I ordered the fuel pump on a certain autopartswarehouse store before and giving me some coupon discounts for future purchases. you guys might also try them as well.
Anna_Keyee is offline   Reply With Quote
Old 03-16-2015, 08:37 AM   #44
Drperrin
Drives: 2011 Chevy Camaro RS
Thanks! car in shop now, getting the two fuel injectors changed and hoping the other two will be fine and only misfiring because of timing chain
Drperrin is offline   Reply With Quote
Old 03-16-2015, 08:21 PM   #45
djshawnwilson
Drives: 2013 Camaro SS/2SS
This just happened to me in my 2013 Camaro SS. I've owned the car (bought used) for 10 months, and this is the first problem I've had. I turned right, accelerating through the turn, and the engine just shut off. I was talking on the Bluetooth and that stayed on, but all gauges and dashboard lights were gone. I coasted to a stop, put it in park, turned the key off, and it started right back up on the first try. Drove less than five blocks home and put it in the garage with no issues. I even restarted it in the garage as a test, and it fired right up. After reading the entire string here, I'm guessing this will happen again. Grrrrr. Forgot to mention - the only modification I've made is a professionally-installed Flowmaster 40 Series on both sides. Just the mufflers, not a full Catback. Haven't noticed any change in idle sound, knocking, or anything else since installation a week and a half ago.
djshawnwilson is offline   Reply With Quote
Old 03-23-2015, 07:55 AM   #46
OfficiallyTook
OfficiallyTook's Avatar
Drives: 2010 LLT victory red
I would highly suggest contacting GM for every major issue...
And if you've had your last straw...
I would contact a lawyer...
OfficiallyTook is offline   Reply With Quote
Old 07-05-2015, 12:39 AM   #47
BlackGen5
BlackGen5's Avatar
Drives: 2010 Black 2LT/RS
Ok I'm dealing with the same issues, just got my Camaro on 6/30. On 7/2 while driving on the interstate the cars engine loses power and eventually stalled out, luckily I was able to get to the shoulder before it stalled. I started the car up and it drove like normal for MOST of the day, (it did it again that evening) check engine light was on from 1st occurrence. Again started back drove home fine. Drove by advance auto just to check the codes, ended up being a total of 19 codes (most repeating) but 6 were misfires in all 6 cylinders. Took it to dealership on 7/3. They said they updated the ECM/ECU and cleared the codes. They said they couldn't recreate the issue after the update. Drove it straight home drove and acted fine. Now today 7/4 does it again this time in the middle of a intersection. Only difference this time was it was a struggle to get it restarted & no CEL was triggered. .of course the dealership is closed on Sunday and I'll drop it off Monday morning, but now I'm no longer feeling safe behind the wheel.
BlackGen5 is offline   Reply With Quote
Old 07-27-2015, 02:12 PM   #48
jujunola
Drives: 2015 Camaro 1LT
my 2015 engine shut off
I purchased a brand new Camaro 1LT on 7/20 an don 7/23, not even three days later, the car engine shut off WHILE I was driving the vehicle. I was able to quickly pull to the side of the road, take the key out and restart the car. I brought it to dealer's service department immediately and they have had the car since then and haven't not found anything wrong with it, they have not been able to recreate the problem. Wth could be wrong with it?
Are there any laws that protect me as the buyer to either return the car within a certain period of time after purchase, or swap it for another car of the same model, etc. since the car is having issues, brand new, and they can't figure out what is wrong with it?
jujunola is offline   Reply With Quote
Old 07-27-2015, 10:29 PM   #49
2013 Orange SS
2013 Orange SS's Avatar
Drives: 2013 2SS/RS A6
My car first started then shut down, I started it several more time and it did same thing. Then it stayed running and was ok. Then this morning when I started it to pull out of garage it did same thing. Then after starting it several times it stayed running but guages, tach, spedomiter not working, several cel's. Thursday the dealership says then can look at it. Hopefullyit will stay running long enough to drive the 25 miles to dealership.
2013 Camaro RS/SS, L99, Vmax PTB, Z-28 CAI
1966 Chevelle Malibu, 355, 4-Speed
2013 Orange SS is offline   Reply With Quote
Old 07-28-2015, 08:51 AM   #50
2013 Orange SS
Went out and started it this morning and everything is working fine. It healed itself in 24 hours.
Old 07-30-2015, 08:12 PM   #51
2013 Orange SS
They found B101E stored in the ECM reprogramed both modules. They asked me if I had a chip in it. They said it showed that something had reprogramed it.
Old 08-03-2015, 02:17 PM   #52
OfficiallyTook
Come on guys get the picture...
Why you think their dropping engines in every year practically...
And the wiring harness is poop
Crap from 2013 and under... Gonna try my luck again with the new model
Old 09-24-2016, 02:58 AM   #53
C_Amaro92
C_Amaro92's Avatar
Drives: 2015 1LS
This seems like a dead thread at this point but my 2015 LS has done this 3 times now. Every time it's late at night and just after making a hard slow turn. By hard slow turn, I mean parking in my parking spot at my appt complex. It's a manual transmission (and no I'm not stalling the car). When it turns off, I lose lights, power steering, and brakes. It's never done it on the highway so far but it's happened 3 times all in the same scenario. The problem is that I can't recreate it. It happens randomly. Because of that, I haven't bothered taking it to the dealership because the last time I took it for a problem they couldn't recreate, they just gave me the run around and I was out of a car for the better part of a week. Advice?
Sent from my SM-G900P using Tapatalk
C_Amaro92 is offline   Reply With Quote
2lt rs, dies, driving, engine
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 04:34 AM
Camaro VS Mustang Mega Thread Beau Tie Chevy Camaro vs... 3644 03-09-2012 07:45 PM
E85 TUNE RESULT!! bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 327 10-13-2011 06:22 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 07:37 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 06:16 PM
