TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 12-26-2015, 12:01 AM   #1
PharaohsLs3
PharaohsLs3's Avatar
Drives: 2014 Camaro 1SS
Why can't I Hook!?
Hows's it going everyone, Merry Christmas first and for most.
I was wondering if anyone can help me out as to why my camaro doesn't hook when i launch? My wheel set up is 20x9 front, 20x10.5 rear. On M/T Street Comp Tires 275/35/20 front and 305/35/20 rear. I've talked to a couple of friends about this issue I've been having and a lot of possible reasons have risen such as too much psi, side wall of the tire is too stiff, wheels are too large, not warming up the tires. I'm just trying to figure out why I'm not hooking or is it that I'm not launching correctly?
Thanks in advance for all the help everyone
PharaohsLs3 is offline   Reply With Quote
Old 12-26-2015, 06:38 AM   #2
flyby
Drives: 2010 Silver SS
please describe any mods to the rear suspension and your approach to the burnout through the launch, then we may be able to help.
flyby is offline   Reply With Quote
Old 12-26-2015, 07:40 AM   #3
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
X2
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 12-26-2015, 10:00 AM   #4
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
The short answer is that there is no sidewall flex on the low profile tires.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein
PAUL SS is offline   Reply With Quote
Old 12-26-2015, 11:33 AM   #5
Chrispy
11.91 ET Bone stock
Drives: 2015 Camaro ZL1
You're not running drag radials, those are a regular street tire.
Pick up a set of MT ET Street radial SS and you should hook hard at the right pressure and burnout.
Chrispy is offline   Reply With Quote
Old 12-26-2015, 04:03 PM   #6
PharaohsLs3
No suspension mods or engine mods just yet. All i have is a CAI without a tune. and as for the burn out and launch i hold my foot on the break and slowly raise the rpms. Once i get to about 1500 i start applying pressure to the gas and wheels start to spin (Traction control is off, i hold down my traction control button down for about 7 seconds to shut it off completely.) As for launch i do the same thing but i turn traction back on and dont go above 1500 rpm or else the wheels will start to spin every now and than from my own personal experiences.
Old 12-26-2015, 04:09 PM   #7
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
How much cold PSI in the rears?
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 12-26-2015, 04:13 PM   #8
PharaohsLs3
My tires are always in the 34-38 zone. front and rear
Old 12-26-2015, 06:30 PM   #9
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
I usually drop my tire pressure to 25-28 depending on the track prep. Some say to leave them alone, but I've had better luck dropping the pressure.
I usually drive around the water box and do a quick clean off prior to getting staged. I rev to 2000-2200 and slip the clutch while slowly rolling onto the gas. If you stab it, you will spin. If you don't ride the clutch out, you will bog or spin.
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 12-26-2015, 09:45 PM   #10
PharaohsLs3
Well mines an auto, so i usually just keep my foot on the brake and slowly increase the rpms until it feels comfortable cause if i go to high than my back wheels will spin
Old 12-28-2015, 07:42 AM   #11
2010SSRSM6
2010SSRSM6's Avatar
My bad, I saw your name and assumed you were a manual. ProStock John can give you the best advice on how to launch an auto.
Old 12-28-2015, 06:38 PM   #12
Mr. Nasty
Mr. Nasty's Avatar
So your car all stock?? You may be doing to much of a burn out with the street tire to much heat will make street tires grease. Try dropping them between 25 to 30 psi with a lite burn out and leave the T/C off.
Old 01-04-2016, 11:30 AM   #13
ihada69L78
ihada69L78's Avatar
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS
32PSI. Just clean the tires off and leave at 1,000RPM. Should dead hook with a 1.94 to 2.0 60'. That works on the stock Pirelli's.
Currenent rides:
2020 SW ZL1 A10
2019 SW 2SS A10
2017 SW Silverado LTZ
ihada69L78 is offline   Reply With Quote
Old 01-04-2016, 03:42 PM   #14
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
All stock except for CAI?
If at the track I would run the rears at 25 psi cold.
On the street I'd probably run then at just over whatever PSI you need to avoid setting a code... 30psi?
Rolling into the gas quick on stock tires = 1.95 for me a few years ago.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
