11-13-2012, 10:12 AM | #1 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
Noisy Rear End
And no it is not mine! My ZL1 is making kind of a howling noise from the rear end on slow turns and when decellerating. It is at the dealer and they already tried the slip additive but the noise is still there. It is not a grinding noise like others have experienced but more of howling. Please let me know if anyone else has experienced this and if it was resolved. I will also report with what the dealer comes up with.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
11-13-2012, 12:29 PM | #2 | |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
11-13-2012, 12:36 PM | #3 |
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
Sounds like gear noise to me. My 2011 Silverado was noisy like that, took it in and they swapped the gears out. Still noisy so they replaced the entire diff, no more noise.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
11-13-2012, 12:41 PM | #4 | |
HAMMER PILOT
11-13-2012, 12:49 PM | #5 |
ZL1 - The Legend Returns!
Drives: 2013 ZL1 Camaro Join Date: Jul 2012
Sounds like Gear noise, which is typically harmless and sometime caused by break in period. Mine will whine a little on the freeway at about 50-60 MPH.
With brand new gears (or a brand new ZL1) the break in recommends not going over 80 MPH and not driving at a constant speed for a long period of time. In my experience, this is directly related to breaking in the gears. I can remember an old Camaro I put 3:73 Richmonds in and it was recommended to drive at variable speeds and heat cycle the gears to break them in. I followed the break in and still heard some whine. Net- unless its screaming loud, it is likely just some gear noise and very likely harmless. |
11-13-2012, 12:57 PM | #6 |
HAMMER PILOT
I have over 5000 miles
11-13-2012, 01:12 PM | #7 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
The rear should be quiet, make them fix it until it is. If someone thinks gear noise is normal, they need a boot up their ass.
11-13-2012, 01:13 PM | #8 | |
HAMMER PILOT
My thought too, if some don't make noise then all shouldn't.
11-13-2012, 02:10 PM | #9 |
Drives: 2013 Ashen Gray M6 ZL1 Join Date: Sep 2012
Give it the beans! Red line thru first four gears and then I'll bet ya she's nice and quite. She's screaming at you to "ride me like I was meant" stop babying her. She just wants and needs a good smack down. Pedal to the metal please, and could I have another. Give it a try and she'll stop whining.
11-13-2012, 02:14 PM | #10 |
At 5000 miles the only thing that will fix it is a technician that knows what they are doing.
11-13-2012, 02:14 PM | #11 | |
HAMMER PILOT
Just got a call from the dealer, they are replacing the ring and pinion, they found some pitting on them, so much for your advice LOL.
11-13-2012, 07:46 PM | #12 |
Drives: Camaro's, always have, always will. Join Date: Oct 2010
...mine does the same thing, at varying times, and speed. On decel mostly...it whines some. Also, when turning, it's groans and moans at times...it's a noisey car. Case in point...the car moans and groans.... alot..., the tranny, rear axle, pulleys, and supercharger. Noises abound. Relax...it's baked into the cake. HP stuff isn't designed to be quiet, the cuts on the gears and associated parts and surfaces are not made to be quiet, they are made to be durable and stout. If the noise gets worse and persistant over time, then you have an issue.
In Scott We Trust...all others must show proof.
11-13-2012, 09:17 PM | #13 |
Just like the old Muncie M22 they howled also, the exhaust is so noisy on a ZL1 I do not see how you can hear the noise. The noise must be loud.
Most rear ends now days do not make noise. I worked for GM and Dodge back in the 70 s doing auto trans and rear ends. Back then we very seldom had a whining rear ends, what causes the wine is the ring and pinion are not set up correct and it takes some know how how to set the back lash and we put color dye on the gears and look where they touch, also the crush sleeve was a bear to get tight and not go to far. |
11-13-2012, 11:39 PM | #14 |
Drives: Chevrolet's Join Date: Sep 2010
