03-03-2017, 10:13 AM | #1 |
Drives: 2014 Camaro SS Join Date: Nov 2015
Service stabilitrak problem.
Hello again forum, I posted about a week ago, thought the problem was fixed, but it came back.
Ill try to make this short. 2 weeks ago, installed a new CAI filter 1 week ago, at startup. Car ran rough and underpowered. Service stabilitrak came on. Cleaned MAF, did fuse pull 5 and 20 since I thought it was running lean. After that car ran good and strong for about 5 days. This morning as I turned the car on, started fine, but car exhaust sounded weaker. 10 minutes into my commute, service stabilitrak came on with CEL and went underpowered again. Last week when I looked at codes it was P0308 which was cylinder 8 misfire. I am at work right now so I don't have my code reader and can't check. People are talking about the battery. The battery is about 3 years old and its the original. Granted I keep it on a tender if I'm not driving for over 2 days. But the battery will stay at 14.8 to 15.1 volts. So I'm assuming its losing its charge. I have checked the wires to the cylinder and everything looks correct. Let me know if anyone needs pics of anything, I can get that. I just want to fix this. What boggles my brain is that this morning it came on in the middle of my commute while I was doing 65 on the highway. Thank you in advance. |
03-03-2017, 11:31 AM | #2 |
Drives: '10 Camaro 2SS Join Date: Jul 2013
Wheel speed sensor or bad plug/coil/wire on #8. Go to autozone and rent the expensive scan tool that checks abs codes and see what the stabilitrak code is. It's around $250 to rent the tool but get it back when your done.
03-03-2017, 02:30 PM | #3 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Very handy tool to have .......INNOVA 3160
OLD GUY FLYING FAST AND LOW
03-03-2017, 04:38 PM | #4 |
Drives: 2010 Camaro 2ss procharged Join Date: Apr 2015
Stabiltrak
Change the coil pack. In that cylinder. And check the connection on injectors. I have chased the same problem and that was the fix
03-03-2017, 06:35 PM | #5 |
03-05-2017, 03:23 PM | #6 |
So the problem went away when I went to dealership, so they could not diagnose it. I guess the moment it comes back ill have to take it.
03-05-2017, 08:09 PM | #7 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
Thats always the way it goes lol.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
Tags |
camaro, cel, ls3, stabilitrack |
