dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 05-22-2011, 07:19 AM   #15
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
Originally Posted by mtcwby View Post
I have all the same mods to the rear end, billet caps, posi mod, pfadt's stiffest bushings, plus the Pfadt engine mounts. The 3.91's from LPE AAM are as quiet as stock.
This. If the gears make more noise than stock there is a shim incorrect, or the backlash was not set properly on install. Take it back to the installer and have them double check. They may charge you for more gear oil, but it's a lot better than replacing ring/pinion + carrier when it finally eats itself from the setting being off.
Aries240SS is offline   Reply With Quote
Old 05-22-2011, 09:42 AM   #16
ADIO SS
ADIO SS's Avatar
Drives: 2010 White SS/RS L99
Originally Posted by NipTuckTaxi View Post
would there be any benefit ( or is is even possible) to replace my L99 3.27 gears with the LS3's 3.45's?
Went that route = about a 10% difference - was not looking to make it a track car. Picked up an M6 diff from someone installing a 9" diff - all you have to do is swap it out. Going $ for a low mileage diff is between $600-750. Try to find local as shipping would get $$$$.
ADIO SS is offline   Reply With Quote
Old 05-22-2011, 09:56 AM   #17
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
Just about all the people that put our 9" in on a manual car are going with 3:70 gears.
Driveshaftshop is offline   Reply With Quote
Old 08-15-2016, 05:02 PM   #18
darcycook
darcycook's Avatar
Drives: 2013 v6 auto 1LT
Originally Posted by LS7 427 View Post
I have the AAM 3.70's from RPM Transmission in my A6 car. Love them, no noise at all. Made 15 passes at the track last weekend without any problems.
i have at he same set up 370 and RPM, put them in the v8 rear end , have yet to have all instaled was needed a programer for the speedo and now hyperteck has a programer for the speedo for my v6 auto 13 camaro question will i need a auto. tran. tune or will the speedo fix me to be good im a daily driver not a racer thanks
darcycook is offline   Reply With Quote
Old 08-15-2016, 08:11 PM   #19
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
5 year old thread
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
3.73, differential, gears
Pfadt Race Engineering DIY Drop Spring installation procedure PfadtRacing Suspension / Chassis / Brakes 20 09-23-2011 09:31 PM
JRE 3.73 rear end w/ posi installed.....questions Fiftydriver V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 04-17-2011 07:04 PM
Whipple SC installation compared to Maggie installation Fiftydriver Forced Induction - V8 8 02-12-2011 11:56 AM
5th gen vs 4th gen JCO2185 Chevy Camaro vs... 158 07-26-2010 08:16 AM
2010 Camaro MagnaCharger + INSTALLATION hoekdup Forced Induction 4 11-28-2009 04:50 AM
