Vararam
Old 10-15-2020, 05:18 PM   #1
jame2ss
Drives: 2015 Chevrolet Camaro 2SS
L99/6L80E Issues
hey guys, having some problems with my transmission as of recent. The car is a 2015 2SS with an L99 and the 6l80E. The trans does not want to shift at anything above light throttle all the way through wide open. However, the only time it appears to be an issue, is the 2-3 shift. The car has a set of headers, a catback exhaust, a cold air intake, and a street tune from a local performance shop. I brought the car to the tuner first, and he could not find a problem with the tune, and even after resetting the trans to the stock tune, it was still having the same issue. Any, and I mean any, insight will help. I'm pulling my hair out trying to figure out what could be causing this. Just had the trans flushed as well by the dealer at 55k miles.
jame2ss is offline   Reply With Quote
Old 10-15-2020, 07:11 PM   #2
RJT Impala
Stovebolt BluFlame 6
RJT Impala's Avatar
Drives: '12 2LT/RS, IBM; '20 Traverse Prem
Was it an issue before the tranny flush?
RJT Impala is offline   Reply With Quote
Old 10-15-2020, 07:19 PM   #3
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
How about when you shift in manual mode with the tap shift? Have you tried different traction control settings? May want to check fluid level also. I'm sure the techs at the dealer filled it properly but you never know.
ariZona28 is offline   Reply With Quote
Old 10-15-2020, 08:05 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I wonder if the tuner tried an adapt reset/relearn. Arizona28 has a good point concerning behavior in Tap Shift mode.
I would be checking fluid levels first off. Dealer service bays are not immune to mistakes.
InFiD3ViL is offline   Reply With Quote
Old 10-19-2020, 10:06 AM   #5
Inferno dogg
Inferno dogg's Avatar
Drives: 2010 Camaro 2SS
Mine will slip between 2nd and 3rd on first start up. It will not do it after that until it cools all the way down again.
GPI SS3 cam with top end goodies,Circle D 4c 3800 w/Derale trans cooler kit sold by GPI,3.90 yukon gears,Kooks long tube headers,Roto fab cold air intake, Corsa extreme 3" cat back, Dyno tuned by Andrews Auto Georgetown MI, Heritage Grille, T4 splitter with under tray, Anvil spoiler,MRR 228 reps with Nitto NT555G2 tires 315 rear 275 fronts,BMR poly bushings,HD Diff cover from RDP,Raytech install kit
Inferno dogg is offline   Reply With Quote
Old 10-19-2020, 06:51 PM   #6
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I lost a torque converter after a tune. Can’t say if it was related or not. But imo, it was. Never the less, shifts got all jacked up. Hung in gears, NEVER would go into 6th, early, high rpm downshifts, higher rpm upshifts, etc. Finally got the CEL. Had to replace the TC. Dealer job...
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is offline   Reply With Quote
Old 05-13-2021, 10:03 AM   #7
2014Cama
Drives: 2014 Camaro SS / 2SS
hey guys .Im having trouble with my trans shifting up in M tap mode on its own .
2014Cama is offline   Reply With Quote
Old 05-13-2021, 02:51 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Are you saying it doesn't upshift on it's own in M, tap mode? If so, it is not supposed to till YOU do it.
1JEWLDSSRS is offline   Reply With Quote
Old 05-13-2021, 03:50 PM   #9
Moto-Mojo
Moto-Mojo's Avatar
^^ This. If not, Are you tuned? Recently?
Old 05-13-2021, 06:51 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Guess he didn't really have a problem and figured it out? lol.
Old 05-14-2021, 07:38 AM   #11
2014Cama
morning peeps. Yes ,stage 2 cam . cold air intake .kooks headers ,Borla Exhaust .
tuned by CJ tunes .
Set in Manual mode . Ill tap shift up the gears . most often . Tap into 3 rd . on its own . will go to fourth, right away . sometimes 4th to fifth. no engine lights, more often at higher speeds, does not hit the limiter.
Old 05-14-2021, 07:40 AM   #12
2014Cama
took it to the shop that put the tune in. and installed the cam .Excellent shop known around the metro for his good work .
Do you think he could get it to up shift .... not
Old 05-14-2021, 07:50 AM   #13
Moto-Mojo
Moto-Mojo's Avatar
Again, as strange as a torque converter sounds for creating tap and auto shift issues, that’s what mine was. It took quite a while for the CEL to light. Right after a tune!
Old 05-14-2021, 08:22 AM   #14
2014Cama
Very strange . I was thinking it was the switch itself . I would have thought The Tuner/ mech. Would have figured that out . Still at the shop , Im telling him to keep it until it up shifts on him . Like have a horse with three legs .
issues, l99, shifting, transmission
