03-31-2017, 09:24 AM | #1 |
Drives: 2017 2SS Join Date: Jun 2014
Jacking points - Mythbuster Edition
Been reading a lot about jacking points. Seems that many swear that we need special jacking pads, that they can only go in one place, and that the car will implode if we don't use them (OK, I might have made that last one up). I've seen pictures of underbellies of cars where someone used MS Paint to circle supposed "jack points". I've even seen videos where people pointed at certain parts and said, "See this? This is aluminum - don't jack here."
But, I knew there was a problem with this theory. After all, when the professionals deliver the car, they don't tie them down with tire straps. They attach straps to hard points UNDER the car. And, these hard points have to be near the edges of the car. And, it stands to reason that if they are reinforced enough to hold a car on a trailer with a tiny T- or J-hook, they should be strong enough to support the car on a jack or jack stand. So, I decided to investigate. Sure enough, there's steel under there. Here's a picture of the front jack point of the car (assuming you have a real jack that has ~12 square inches of area on the jacking pad - not a scissor jack). It's just rearward of the front wheels - the black part with 2 big holes and 2 small ones. (note - I took this pic after jacking the car up, and there is no noticeable mark, denting, or deformity) And, to prove that it's steel . . . . . . I stuck my magnetic bowl to it. So, if you want to buy fancy jacking thingies for your car, have at it. But, if you want to just jack the car up and get to work, use these points. |
03-31-2017, 09:30 AM | #2 |
Defending the Nation...
Drives: '16 Summit White 2SS, A8, Sunroof Join Date: Dec 2009
I love common sense! Thanks!
'16 2SS, A8, Sunroof, non-NPP "SURSUM AB ORDINE" |
03-31-2017, 09:32 AM | #3 |
Drives: 2016 Red Hot 2SS Join Date: May 2016
IMHO, the fancy bolt-ons thingies are for two reasons:
1) reduce the chance of twisting the pinch welds when you lower on the jack stands 2) reduce the chance of some dealer guy not padding the jack arms and ruining your rocker panels. The spots you are recommending are not the GM recommended jacking spots. |
03-31-2017, 09:34 AM | #4 |
Drives: ^^^This Join Date: Nov 2015
What part of the car is that "steel" part? What is it?
03-31-2017, 09:44 AM | #5 | |
Yes - the "Owner's Manual" says to use the pinch welds. But, remember, those manuals aren't written for gearheads. They're written for average Joes. And, the average Joe doesn't have a nice floor jack with a wide pad. They are writing the manuals for people that have a scissor jack left over from their 1985 Malibu, or a bottle jack from their dad's 1974 F100. |
03-31-2017, 09:45 AM | #6 |
03-31-2017, 09:47 AM | #7 |
Drives: 2016 1SS Join Date: Jan 2016
1SS, Black, Black Wheels, A8, MRC, NPP
03-31-2017, 09:51 AM | #8 | |
Loves Camaros
Drives: Red '79 Z28, '21 Red Hot M6 ZL-1! Join Date: Sep 2012
Old and new, sharing space!
03-31-2017, 10:05 AM | #9 | |
I'll definitely examine the spot you have mentioned next time I go under the camaro. |
03-31-2017, 10:09 AM | #10 |
Ok....so let's say we can use these 'new' jack points. Where would you locate the jack stands?
PS- I lift my car from the center front point and the center rear black bar and put my stands on the pinch welds. The rear black bar works great. The center front point also works well, however is did bend a little.
03-31-2017, 10:21 AM | #11 | |
Should be no problem using the OP's spots with a wide quality floor jack. Personally don't think putting jack stands on the pinch welds is going to hurt them if done right. I know I didn't bend/damage mine on my last oil change. Just lowered the car slowly onto the jack stands. The issue comes from jacking on the pinch welds.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) Last edited by SuperSound; 03-31-2017 at 10:33 AM. |
03-31-2017, 10:30 AM | #12 | |
For reference, that magnetic bowl is about 6" diameter. There is plenty of room to fit both. |
03-31-2017, 10:37 AM | #13 |
But that spot is slightly further up then the outer trim. If the car-lift pads are worn or to thin or the cars placement is off, the lifts main arm support will press into the plastic trim.
Some techs will look and maybe catch it, others might not or think its plastic and will just flex, but it won't because the way it is made. So it leads to the plastic being compressed up and damaging it, even more so with a GFX kit. Adding the items to the pinch welds, just adds a little more protection and less chance of loosing time with your car as the dealer fixes their mistake. Here was what happened to me, but i have seen worse. |
03-31-2017, 11:14 AM | #14 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
If your jack has enough area you can probably lift it where you show. I have the pinch weld adapters so no need to chance it. Also... I had the passenger/front area like that crush slightly on my old 2004 GTO after years of being ok
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
