01-02-2023, 08:57 PM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
2015 Camaro SS FS
Hi guys. Sadly with work and life I do not have any time for the Camaro these days. Looking to sale. Have title in hand. Car is heavily modified, but runs and drives great. Fully streetable and runs! Located in central PA. Serious buyers shoot me a pm and I can give you my cell for any more info. Car has never seen a track! Thanks
2015 Camaro SS w/2SS package. Power everything, including sun roof. Windows tinted, Heads up display, heated leather seats, auto ect ect... 6.2 engine 66125 miles. Clean title in hand! Less than 3k on full build. Car is in great shape and has been in a climate controlled garage since the day I purchased it. Mods: 1. Full GPI max top end kit 2. LS7 intake 3. LS7 style GPI max heads. They flow over 400 cfm intake, 270 exhaust, 2.18 intake valves, 1.59 exhaust 4. SS3 GPI max cam shaft 5. Cloyes LS3 timing gear 6. C5R katech timing chain 7. LS2 timing chain dampner 8. GM performance lifters 9. BTR valve springs and titanium retainers 10. GPI chrome moly push rods 11. LS7 fuel rails 12. 1.8 roller rockers with trunion upgrade (smith brothers) 13. ARP bolts everywhere I could. Heads, cam retainer, timing gear, flex plate, torque converter and balancer 14. ZL1 fuel pump 15. JMS boost a pump 16. ID 1050 injectors 17. Jannetty FPCM 18. ESS complete supercharger system with vortech head unit, 6" front mount intercooler 19. 95 mm pulley for a couple more pounds of boost and 2 complete blower oil changes included 20. DOD/AFM deleted, LS3 conversion, VVT delete 21. BMR poly engine mounts 22. prothane rear poly cradle bushings 23. DSS carbon fiber one piece drive shaft 24. Fluid dampner crank balancer 25. Corsa extreme 3" full exhaust 26. 1 7/8" stainless long tube headers 27. Circle D pro 245mm 5C 4200 stall converter 28. Trucool 40k transmission cooler 29. Mishimoto aluminum Radiator and 170 degree t-stat 30. Improved racing oil pick up girdle 31. MSD spark plug wires and protective boots 32. Jannetty trans dipstick 33. JLT 3.0 oil catch can 34. 3 bar map sensor 35. NGK spark plugs TR71X (3690) 36. improved flow AC delco trans filter 37. Tubular front crash bar 38. Full factory 391 rear end 39. dual gauge pod in top left dash vent with AEM wide band and boost gauges 40. Race star 5 spoke aluminum wheels rear 17x10.5 mickey thompson ET streets SS 305/45/R17 front 17x7 milestar 235/60/R17 All tuning completed via HP tuners and completed by Ted Jannetty Tuned for 93 octane and currently running 9lbs of boost. Ted stated we could drop in the 95 mm pulley safely and tune again, but I left it at 9lbs. Car is very strong! I'm sure Im forgetting some mods, but I have record of what was done along with all the papers and manuals and part numbers for as much stuff as I could. I have a build thread on here that I will try and post a link to. Only serious buyers please! $27000 obo
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
01-02-2023, 08:58 PM | #2 |
01-02-2023, 09:00 PM | #3 | |
Many on here have seen this video many times over the last couple years haha. This is idle and walk around before the supercharger install
01-02-2023, 09:06 PM | #4 |
01-05-2023, 06:41 AM | #5 |
Well over $20k invested! Car is in very nice shape, inside and out. Always willing to listening to offers. Thanks!
01-05-2023, 03:47 PM | #6 |
Drives: 2013 ZL1 Join Date: Mar 2013
I went thru your build of the motor and almost the last post you said you were going to put it on a dyno. Did you? If so what kind of numbers did it lay down?. You stated you put a blower on it then I see a different intake and no blower? Help me out here if you would. Thanks
01-07-2023, 01:22 PM | #7 | |
01-10-2023, 12:24 PM | #8 |
Car is now sold. If the buyer backs out, I'll relist. Thanks
03-18-2023, 07:27 AM | #9 |
Drives: 13 ZL1 vert blac fastlane/LPE 750 Join Date: Jul 2011
Did it sell ?
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
03-18-2023, 07:48 AM | #10 |
It don’t come easy.
Been a couple months. I would guess, yes.
