05-08-2018, 08:55 PM | #1 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
GM part numbers for rear FE4
Hello all,
What OEM parts name and number do I need at a minimum for the rear sway bar upgrade. I was thinking either the recommended ZL1 27mm bar or an aftermarket bar. Is is just the trailing arms that I need?
05-08-2018, 11:48 PM | #2 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Can't help you until I know what you drive. Try searching the multitude of GM part's distributors on the internet.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-09-2018, 04:26 AM | #3 |
Apologies. 2010 ss.
05-09-2018, 05:50 AM | #4 |
Hotwheels
Zl1 / 1le rear sway bar setup
End links 22761221 need 2 Sway bar 22786260 2 Rear Lower Control Arm (SS, ZL1, 1LE) (2) - 20942237 (Needed for 2010-2011 car conversion) Sent from my SM-G955U using Tapatalk
05-09-2018, 02:46 PM | #5 |
Can these be driveway installed or are there special considerations or removal of parts?
05-09-2018, 03:08 PM | #6 |
Hotwheels
Depends on your macanical skills
Jackstands Will work to. Access Everythihg Sent from my SM-G955U using Tapatalk
05-09-2018, 10:24 PM | #7 |
gmpartshouse.com has a zl1 rear sway bar kit for dirt cheap. Has every thing you need to convert.
05-11-2018, 10:42 PM | #8 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Can do in driveway. 18mm and 21mm sockets and wrenches. Torque everything down after you put weight on the car. You will need and alignment.
05-11-2018, 11:47 PM | #9 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
https://www.camaro5.com/forums/showthread.php?t=371323
https://www.camaro5.com/forums/showthread.php?t=381401 Did mine on jack stands... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
05-12-2018, 04:16 PM | #10 |
MOD SQUAD
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII Team LS3 |
05-12-2018, 05:02 PM | #11 | |
05-12-2018, 08:28 PM | #12 |
MOD SQUAD
I believe new ones come with the 1LE conversion kit. Just normal stamped OEM parts. I installed the BMR on my Camaro.
05-12-2018, 08:29 PM | #13 |
Gotcha..
