10-25-2016, 07:13 PM | #29 | |
Drives: 2016 Camaro 2SS NFG M6 MRC NPP Join Date: Mar 2016
http://www.chevrolet.com/content/dam...ers-manual.pdf If you shutdown the car when it's in Snow/Ice or Track mode, it will reset to Touring mode by default when you turn the car on again. If it's in Touring or Sport Mode when you shutdown, it will stay in that mode. |
10-26-2016, 10:17 AM | #30 |
thats why he specified you need to go into ACC mode before you start the car and switch to snow/ice before firing it up
10-26-2016, 11:44 AM | #31 |
ummmm
Drives: 2016 2SS M6 Nightfall w/Blk Wheels Join Date: Jul 2016
10-26-2016, 11:50 AM | #32 |
Drives: 2016 Summit White Camaro 2SS Join Date: May 2009
I learned something new, I'll gladly go into ACC mode to make the change when I start up in the morning.
My driveway is only about 10 feet away from my neighbors house and there is no way that starting up in anything except Stealth wouldn't wake them up at 7 am every day. Thanks for the tip! Last edited by merlin803; 10-26-2016 at 12:17 PM. |
10-28-2016, 08:09 AM | #33 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
FWIW.. I tested this out yesterday. I did the ACC mode and changed the exhaust to Stealth. It still BARKS really loud when you fire it up. It did quiet down the rumble compared to the open valve sound but still not at all what I would call a stealth startup.
10-28-2016, 08:13 AM | #34 |
Retired from Car mfrs....
That's what I thought...the valves are electric and when power is turned off they default to open, when you startup and power is just getting to the valves, they bark for a second and then close as they get energized.....even in stealth.
10-28-2016, 08:18 AM | #35 | |
Not ideal but at least it is an option if your neighbors are coming out with the pitchforks, lol. |
10-28-2016, 09:26 AM | #36 |
SABIO
Yes. Stealth has to be set before you shut the car off.
10-28-2016, 09:53 AM | #37 |
Drives: 1968 SS/RS, 2006 H2 2016 2SS White Join Date: Sep 2015
Your neighbors are going to love you! When you start the car in the morning, it is as quite as a mouse.
2016 2SS White fully loaded
10-28-2016, 12:18 PM | #38 |
ummmm
I had a feeling this might be the case. It is hard to test different sequences as it only really barks when engine is completely cold... (i.e. first start in morning) I was going to test the menu setting yesterday morning, I held the Start button... but I did it wrong and the engine started... (vrrooom!) I gotta try again today.
10-28-2016, 06:34 PM | #39 | ||
With the NPP fuse back in and 'Engine Sound Management' settings is set to 'Auto', this has always worked for me to keep my car as quiet as possible. My current set up is borla x-pipe #60606 (2nd cat delete) to factory NPP and RotoFab CAI, so these mods increased the sound by a lot. |
10-28-2016, 06:36 PM | #40 |
Does not matter ....when you turn the car off, completely off, and walk away, the valves open up again, that's what causes the start up bark.
10-28-2016, 06:48 PM | #41 |
Yes that does happen, so you would need to re-enable Ice/Snow mode before you turn on the car to decrease the "bark" sound on start up.
10-28-2016, 06:50 PM | #42 |
That won't work either because there's no power going to the valves for a split second,when you start the Car!
