02-21-2024, 06:32 PM | #43 | |
Drives: 2011 Camaro 2SS/RS Join Date: Nov 2023
2011 SS/RS K&N Cold Air Intake, Borla Atak Cat Back, Niche 20" Wheels. More to come...
02-21-2024, 06:35 PM | #44 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
Will do! Thanks!
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
02-21-2024, 11:17 PM | #45 | |
Drives: 2SS/RS Join Date: Sep 2008
When I took mine in last year with freon issues the shop told me they couldn't see anything either. When I got home, I parked the car in a dark area of the driveway and looked. The engine bay lit up like a christmas tree. |
02-22-2024, 04:21 AM | #46 | |
I believe you and i’ll do that. Sent from my iPhone using Tapatalk
2010 2LT/RS
02-22-2024, 04:14 PM | #47 |
I recently pulled the car into the garage and turned off the lights. My findings of the leak seem to be coming from this sensor of some sort where it clips into the hard metal line…
2010 2LT/RS
02-22-2024, 04:19 PM | #48 |
Its right below where the black cap is on top. More pics…
2010 2LT/RS
02-22-2024, 04:20 PM | #49 |
Intake tube and oil cap is lit up.
2010 2LT/RS
02-22-2024, 04:23 PM | #50 |
2010 2LT/RS
02-22-2024, 05:02 PM | #51 |
This cap is the high pressure port. Unscrew the cap (it's just finger tight) and take a look at the port and see what it looks like. From the other pics, it looks like the port is leaking and the cap is spraying the mist downward.
02-22-2024, 06:00 PM | #52 | |
Here is a pic of the high pressure port…. Sent from my iPhone using Tapatalk
2010 2LT/RS
02-22-2024, 08:41 PM | #53 |
Yep it's definitely leaking.
02-22-2024, 09:08 PM | #54 |
Good to know this and THANKS! I will have them correct it as I show them the pictures during my next visit! Sent from my iPhone using Tapatalk
2010 2LT/RS
02-23-2024, 01:59 PM | #55 |
I believe it finally happened... AC blend door??
Turns out its not the high pressure port. I was told it was the evaporator above the transmission that is leaking and the whole friggin dash has to come out! WTH!! Can someone tell me there is a way around this??
2010 2LT/RS
02-23-2024, 02:01 PM | #56 |
2010 2LT/RS
