Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Rockies / Midwest
Old 08-15-2015, 10:12 AM   #29
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
What brand of half shafts and rear diffs is every one running and what do you think is the biggest bang for the buck? Which one are to be avoided
Moreair1 is offline   Reply With Quote
Old 08-15-2015, 01:02 PM   #30
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Gforce 9" here.
Best bang for the buck is the ZL1 setup if you are buying new. However, depending on what you will do with the car (toy vs race car and what kind of racing - autocross, road race, time attack, drag racing, 1/2-1.5 mile events) it might be cheaper in the long run to go with a 9" or S60 set up. You know, the "buy once, cry once" kind of deal.
Automatic vs manual also fits here. A manual is harder (drive line shock) on parts than an auto but again, what kind of racing? Drag racing is harder on the drive line than the others I listed. Endurance events seem to be harder on the engine than the trans and rear end. I posted a lot of generalities here but just wanted to share some insight.
There is also the stock differential you can upgrade with an Eaton tru track, billet caps, LPW cover, and aftermarket axles.
I suppose you have to ask yourself "what is my budget?" and weigh that against "what do I want?"
Old 08-15-2015, 09:15 PM   #31
Moreair1
Moreair1's Avatar
To be honest probably just a toy, I won't do a roll bar so anytime I run faster than 13.5s I will be asked to leave or slow down at the track, but I agree with you when my stuff does break buy the stuff that will last and yes that usually does make you cry and the sales man cry one in a omfg way that was alot of Dinero and the other in rejoice going ca ching but I do plan having this car along time and to also teach my son how to work on cars with this one
Old 08-20-2015, 09:57 PM   #32
Moreair1
Moreair1's Avatar
Big agp intercooler
Old 08-23-2015, 05:22 PM   #33
Moreair1
Moreair1's Avatar
Think I will be doing a g force 2 boost controler, I want to conceal it so it can't be seen so I'm thinking maybe velcro under the instrument panel so I can lay it flat or have it hang down when I need it, and I will be able to see my boost level through my hud so I won't need to have it visible except when I want to play with my boost
Old 08-25-2015, 10:49 PM   #34
Moreair1
Moreair1's Avatar
Decided the intercooler is Going stick out to much so going paint it flat black with radiator paint, any one have a good recommendation on which brand to use?
Old 08-26-2015, 09:45 PM   #35
Minator
Minator's Avatar
Drives: 2014 Chevy Camaro ZL1
Hellion has a great setup. That is what I did
Minator is offline   Reply With Quote
Old 08-26-2015, 11:21 PM   #36
Moreair1
Moreair1's Avatar
Minator that's a good lookin set up, and the intake manifold just sets the whole package off very nice
Old 08-30-2015, 03:41 PM   #37
Moreair1
Moreair1's Avatar
Intercooler painted flat black (more stealthy)
Getting closer to actually being able to start this project
Old 09-29-2015, 12:21 AM   #38
Moreair1
Moreair1's Avatar
Ok sorry about the delay but I should have some build pictures coming soon
Old 10-06-2015, 07:45 AM   #39
Moreair1
Moreair1's Avatar
The starting point
Old 10-06-2015, 10:00 AM   #40
Moreair1
Moreair1's Avatar
Well only had a couple hours to work on it, should be further along but spent to much time on looking for tool exhaust is ready to drop, coil packs are off and ready to remove 10 more bolts to drop the front end and ready to have to disconnect some hoses and will be ready to remove the intake manifold
Old 10-06-2015, 06:24 PM   #41
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
Off and running. Good luck.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 10-06-2015, 07:38 PM   #42
Moreair1
Moreair1's Avatar
Thank you, I was noticing your coil pack sit different, is it because the motor you have in it?
