07-28-2013, 09:50 AM | #1 |
Drives: ELLE-1 Join Date: Jul 2011
RX BREATHER ????
NO REASON TO HAVE IT ON MY CAR....from what ive read unless your at wide open throttle there is really no reason to have this on your car...i took mine off and went to stock oil cap with catch can....i know its only letting air in and not out but thats got to mess with fuel trims in some way ....im just not going to take a chance
07-28-2013, 10:33 AM | #2 | |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
This is all good, but make sure you put the clean side intake back together.
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
07-28-2013, 10:36 AM | #3 |
Drives: 2010 Camaro Join Date: Feb 2010
I use a Metco breather but the same principal applies. I only use it on track days. Other than that the stock oil cap goes back on.
07-28-2013, 10:41 AM | #4 |
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
You've got it backwards, again. The breathers one way valve only lets crankcase gases out, not in. So that when you are making too much pressure for the pcv to handle it blows off through the breather and doesn't blow out your engines seals.
The reason they say track days only is because according to the epa, you cannot evacuate any crank case gases to the outside.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
07-28-2013, 11:03 AM | #5 | |
With no breather on Ill push oil out the rear main seal. |
07-28-2013, 11:14 AM | #6 |
I drilled out the pvc hose barb in the valve cover and removed the check valve from the catch can. No more weeping rear seal.
07-28-2013, 09:13 PM | #7 | |
07-30-2013, 12:28 AM | #8 |
Drives: pleather and Chiclets Join Date: Mar 2012
1le oil separator!
07-30-2013, 11:26 AM | #9 | |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
07-30-2013, 03:47 PM | #10 |
Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Wrong.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
07-30-2013, 03:52 PM | #11 |
Drives: 2013 2SS 6M Join Date: May 2013
Strut tower brace(GM), CAI, Blade Spoiler, ZL1 wheels and tires, Heritage grill, Dual mode exhaust, and thats it, no more..except for the lowering springs..Ok Hotchkis springs were delivered today, thats it..
