dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 04-18-2014, 09:57 AM   #1
I call it Vera
Drives: ZL1 Convertible
ZL1 Stock Tires - How many miles
Hi,
I have a few questions about the stock tires on our ZL1(s)
  1. How many miles did you typically get before the tires need replaced?
  2. How can you tell? How do you know when the tires need replaced? So little tread pattern, hard to tell from typical tires . . .
Thanks!
I call it Vera is offline   Reply With Quote
Old 04-18-2014, 11:06 AM   #2
knowitman
Camaro fan since birth
knowitman's Avatar
Drives: 2013 ZL1
I have 7000 miles on mine, and the tires have a lot of life left in them. In one of the grooves you should see a small notch which is the wear indicator. The notch in the groove is the same height as when you should replace your tires.
http://www.thetirechoice.com/learnin...pth-tests.aspx
Sent from my SAMSUNG-SGH-I337 using Tapatalk
knowitman is offline   Reply With Quote
Old 04-18-2014, 11:06 AM   #3
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
2. There have to be wear bars in the tread that, when you're worn down to them appear as solid rubber strips across the various tread grooves.
1. It's heavily dependent on your driving and on how well your car's alignment and inflation pressures suit that specific driving. Some people barely get 5000 miles per 100 rated treadwear. Other folks can get 10,000 or more per 100. I can usually get 12,000/100 or a bit more on any car with any tires and I don't drive gently (but I don't drag race or do burnouts, which are huge influences).
Norm
Old 04-18-2014, 11:21 AM   #4
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
I have 17,000 miles on my original tires and they are done. The rears are worse than the fronts (as they should be!). That includes some autoX at the past 2 Camaro5Fests and probably 15 drag strip runs with light burnouts.
The rears don't grip anymore and the tread is almost down to the wear bars. The fronts probably could go a little longer, but I will swap the set. The new ones will be installed before my drive to Camaro5Fest. I picked up a lightly used (1,000 miles) set of tires off a 1LE and will be running a square setup. I got such a good deal I couldn't pass it up!
Deke736 is offline   Reply With Quote
Old 04-18-2014, 11:23 AM   #5
PNYSLAR
Summit White 2012 ZL1 M6
PNYSLAR's Avatar
Drives: 2010 BLACK 2SS/RS M6 Delvd 8/24/9
12,500 and need replacing
2012 Summit White ZL1 Manual 6sp Blk 10 spoke, "Thanks Champion Chevrolet" delivered 6/9/2012 #1588
PNYSLAR is offline   Reply With Quote
Old 04-18-2014, 11:38 AM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
11,000...some life but not great
Old 04-18-2014, 11:48 AM   #7
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
About the same here. I have about 18 k and the fronts are almost to the wear bars. The rears were done around 16k and I had bought two rears from a friend about a year ago for $150 and I had put them on back in December. Now those are about the same as front. I have had to daily drive my car since November so I drive a little more aggressive. Just can't help it, I just love this car.
KLR ZL1 is offline   Reply With Quote
Old 04-18-2014, 12:20 PM   #8
2012-1822
2012-1822's Avatar
Drives: Black ZL1
First, check your wear markers.
Second, depends on what you do with your car. I don't really do any HPDE or AutoX, so I probably didn't wear mine as fast as some. I launched on a dag strip about 100 times on the original set. So the rears were pretty well gone when the fronts still had some life. I got 22,500, but I probably went just a little long. Maybe closer to 21k would have been better.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 04-18-2014, 12:35 PM   #9
Drbormd
Drives: 13 F150 Eco 14 ZL1 650 RWHP
10k and done
Drbormd is offline   Reply With Quote
Old 04-18-2014, 03:16 PM   #10
Bowtie724
Drives: 2000 Camaro SS 2013 ZL1 Camaro
8000k and mine are done. Not a daily driver (meaning I really test the tires every drive)
Bowtie724 is offline   Reply With Quote
Old 04-18-2014, 03:53 PM   #11
Drew P
Drew P's Avatar
Drives: Camaro ZL1
11k and they were slicks. I kept very close attention to the PSI, but daily drive like i am in a police chase, meaning i spun the back tires at least 2 or 3 times a day, plus quite a few trips to the drag strip.
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion.
Drew P is offline   Reply With Quote
Old 04-18-2014, 04:02 PM   #12
rzrbck_zl1
rzrbck_zl1's Avatar
Drives: '13 ZL1 CRT #702; '05 Hemi Ram
I just replaced the brake pads today with the Hawk performance ceramic pads, and I saw the back tires are almost down to the wear bars. I'm just under 10000 miles. The fronts still have plenty of life left. I don't track it, but I drive fairly aggressively. Planning on replacing the Goodyear tires with the Michelin Pilot Super Sports.
rzrbck_zl1 is offline   Reply With Quote
Old 04-18-2014, 04:09 PM   #13
LS1 Fun
Drives: 2013 ZL1
15k on the stocks and they are bald. They were probably done at 13k but i still have them on. I DD with them and have made 10 passes at the strip. They slide and skid a little, but at least it makes me keep my foot out of it!
1974 Cadillac Coupe DeVille
2002 Camaro Z28 A4 | 10.80 @ 131 | 383ci, D1SC, 4L80E, 9"
2013 Camaro ZL1 A6 | 12.62 @ 113 | Stock *SOLD
2017 Lexus GS350F
LS1 Fun is offline   Reply With Quote
Old 04-18-2014, 06:15 PM   #14
pumpkinrancho
COMPULSIVE CAMARO OWNER
pumpkinrancho's Avatar
Drives: 18 ZLE,14 2ssrs,96,73 RS LT,69&67
11k and they are done. New ones before c5fest5
pumpkinrancho is offline   Reply With Quote
