10-04-2014, 02:25 PM | #1 |
618 RWHP
I am looking for a set of used rims for my ZL1
I will be putting up my ZL1 for the winter soon and I was looking for a used set of rims i could put on it for the winter so i cam take my good rims and tires off and keep in the house . Any one know where i could get them ?
10-04-2014, 03:00 PM | #2 | |
Drives: 2013 CRT ZL1 Join Date: Sep 2012
I am 38 years old and have had sports/muscle cars in central n.y. for over 20 years, always storing them every winter with fuel stabilizer, disconnected battery and car cover. Never once have I took off the tires or put it up on blocks or any bull crap like that and it's always been zero percent problems.... smooth sailing come spring every year. But Hey man with all due respect it's your money so spend it how you will... Sent from my SM-N900V using Tapatalk |
10-04-2014, 04:02 PM | #3 | |
618 RWHP
10-04-2014, 04:28 PM | #4 | |
The threads you read are just people being silly, overly anal. Your tires are going to wear out And need replacement due to just normal wear and tear long before you start getting cracks.. I'm Also pretty sure the manual is saying you shouldn't drive in under 40 degree whether but I've done that too.. you just can't be stupid about it. Sent from my SM-N900V using Tapatalk |
10-04-2014, 04:42 PM | #5 | |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Use that information any way you want. When I still had the stock Goodyears, I'd take them off every winter to store them in my basement and put an old set from my 2011 SS on the car for the winter. |
10-04-2014, 04:57 PM | #6 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
I bought a set of flatstopers as a precaution while stored for the winter. More surface area contact and to get them off the concrete. I'll also air the tires up to 40 psi, put a battery tender and indoor cover on it and then leave it alone until spring.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
10-04-2014, 04:57 PM | #7 | |
10-04-2014, 07:37 PM | #8 |
Drives: Chevy/Dodge/Ford Join Date: Jan 2013
As long as the car stays in one spot and you don’t move it the tires will not crack. It’s only when the car is driven in cold temperatures you get tire cracking in the rubber.
They say money can’t buy happiness; well they never drove a Camaro.
A Corvette engine and a Cadillac suspension stuffed into a Camaro, that’s what I’m talking about! |
10-04-2014, 07:56 PM | #9 | |
Well , be my guest , but if ,,,'happen , it's all on your dime ! |
10-04-2014, 07:57 PM | #10 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Then why is it the tires on my trailers that sit all year have fresh cracks each year? I'm not saying they will crack and I think OP is probably overreacting a bit, and also would be wasting more money buying the used wheels and tires than he would if he had to get new tires. But they can definitely crack without being moved. It doesn't get very cold where I am either, it's just the heat
10-04-2014, 08:52 PM | #11 |
Drives: Maroon 67 rs and CRT 2012 ZL-1 Join Date: Apr 2012
I'm pretty sure the dealers that have these cars on the lot in the winter don't take the wheels and tires off. This will be my first winter with this car and the will be on my car in an unheated garage in the northeast. As long as you don't drive the car they will be fine.simply moving the car from the garage to the driveway the should be fine too.
" No matter how tough you are when a 2 year old hands you a toy phone you answer it"
10-04-2014, 09:10 PM | #12 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
This is bad info.. I called Goodyear when I got my car last year and was reading all this mis information. Goodyear stated they recommend you not move the tire under 20 degrees and as any manufacturers performance tire you risk loss of control under 40 degrees. But they cleary stated the tire will be warrantied for any cracks regardless of temperature use. I have a second set of aftermarket rims with a Michelin AS3 so on a nice dry cold day I can go out if I want.
10-04-2014, 10:24 PM | #13 |
618 RWHP
I like these . What size did you buy for your ZL1
10-04-2014, 10:25 PM | #14 |
Drives: 2013 ZL1 A6 Camaro, 2015 C7 A6 Z51 Join Date: Apr 2014
Man I'm glad that I don't live in the areas that you guys do..In Oklahoma we have an Ice storm or two...Maybe snow for a week or two, but it usually melts away in a day or two...I won't drive my car on the ice or snow, but I am not going to store it all winter either....My wifes car is a 96 vette, we only had a carport till about a month ago and she hardly ever drives her vette..we put new rubber on it about 3-4 years ago (BF Goodrich performance tires) and they have cracks all in them and the tires have 95% tread left...The car sat for about a year and we only went out and started it once a month to keep the battery up on it...I know my trailer tires on my Stock trailer, car hauler and utility trailer all have cracks in them as well...From what? I don't know for sure, but they are there...
Roto-Fab CAI, Texas Speed Headers, Texas Speed X-Pipe, Texas Speed LS3-B Blower Cam, Metco 9.10" Crank Pulley, Metco 2.5 Upper Pulley, ID 850 Injectors, LPE Ported Throttle Body, Alky Control Methanol kit, E2 Catch Can, 610HP / 608 Torque.
