dave@hennessey
Old 04-26-2017, 10:12 PM   #1
icedaccord19
icedaccord19's Avatar
Drives: 2013 Camaro Convertible
Passenger Seat Won't Recline
My passenger seat will not recline and is stuck all the way forward, i did some research on the and tried the instructions that was on document #PIC5579A by the seat back and forth in hopes of it solving the issue but that didn't work. I took it to the dealership and they diagnosed it as micro switch stuck open due to improper use of the seat and in order to fix it i have to replace the entire seat back frame which is $300(parts) + $200(labor) which sounds INSANE to me just because of a bad switch which is probably $20. The dealership is saying the switch is "built into" the frame so you have to get the entire piece. Has anybody else ran into a similar seat repair problem. Thanks!
[IMG][/IMG]
Mrt v2 | Colorshift 2.0 | Rx Oil Breather | Rx Catch Can | T-Rex Billet Grille | HID Retrofit | Push Start | Vitesse Motorsports Throttle Controller
icedaccord19 is offline   Reply With Quote
Old 04-26-2017, 10:46 PM   #2
chargerfan2
chargerfan2's Avatar
Drives: 2014 Camaro SS 1LE 2SS Summit White
What the hell is improper use of seat? You riding around with fat chicks?
chargerfan2 is offline   Reply With Quote
Old 04-26-2017, 11:01 PM   #3
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
$300 sounds good (ill have to look up the parts again)...
My drivers seat wont recline/decline, tried the switch first ($30 online) and that wasn't it.. its the motor for me, replacement of the motor assembly (frame) is like $500 because it has all 3 motors, they don't sell them separately...
Lucky enough I'm the only person that drives mine and its set for me (and hasn't moved in 3 years)..
On a side note, if you want to try and fix it yourself try unplugging the seat (underneath) the motors have built in electronic fuses. once tripped and as long as they have ground they wont reset, unplugging them sometimes 'resets' the motors.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 04-27-2017, 06:31 AM   #4
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
'Improper use of seat' sounds like the dealer trying to get out of any responsibility.
Then again, no warranty at this point anyhow. That's weird.
InFiD3ViL is offline   Reply With Quote
Old 04-27-2017, 07:37 AM   #5
icedaccord19
lmfao!!! well apparently i think from my understanding is you're not suppose to recline the seat all the way forward and then use the release on the back?? idk thats what really upsets me is that i RARELY use my passenger seat and there is some sort of "improper" use of it that can cost me $500....just unbelievable.
Old 04-27-2017, 07:40 AM   #6
icedaccord19
Thanks for this info, if all of the motors are built into the frame then it is what is it, i just dont understand why they made it that way
Old 04-27-2017, 08:09 AM   #7
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
IN 2011 ; I do not believe until the year 2011 they made the passenger seat with a power seat option and it was as in my 2011 2ss rs I owned first a manual seat for moving forward and back as in this the parts break down you should consider when repairing it yourself....... one switch for back that's it.... if it does not reset after unplugging and replugging in the seat just replace the switch... $22.14
http://www.gmpartsdirect.com/auto-pa...omponents-scat
christianchevell is offline   Reply With Quote
Old 04-27-2017, 08:19 AM   #8
icedaccord19
Oh sorry i just noticed i didn't update my profile, i have a 2013 now
Old 04-27-2017, 08:34 AM   #9
christianchevell
well go to gm parts direct if checking the fuses etc do not work...often the harnesses can get messed with being they are just there under the seat.
