TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 05-13-2013, 10:04 PM   #1
NOT URSS
NOT URSS's Avatar
Drives: 2010 2SS/RS Camaro
Send a message via AIM to NOT URSS
l99 to ls3 conversion question
Did a search, but did not find the answer I was looking for.
I am doing the L99 to LS3 conversion and I purchased the new cam position sensor and the new cam position sensor harness. But looking at my factory harness female side is a 5 terminal connector and the new harness connector is 3 terminal which wont plug in. I'm guessing this has to be modified or did i buy the wrong part? Thanks so much
Matt
632RWHP/556RWTQ
NOT URSS is offline   Reply With Quote
Old 05-14-2013, 03:33 AM   #2
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
I'm not sure what everyone else did, but I used original harness minus the plug for variable cam timing as I used 3 bolt cam, but I used the 3 terminal bracket to hold the 5 pin plug to keep it all tidy.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 05-14-2013, 05:36 AM   #3
NOT URSS
NOT URSS's Avatar
Thanks for the reply, still a little confused how u got the factory 5 terminal connector to plug into that 3 terminal connector ... From the looks of that picture looks like the 3 terminal connector on the bottom
632RWHP/556RWTQ
Old 05-14-2013, 05:44 AM   #4
Kiwi_Camaro_2010
Sorry, it is 3 terminal when i took pic, i don't have pic of 5 pin terminal, All I did was open retainer a little where bottom 3 pin was & squeezed in 5 pin minus 2 pins that were used for variable cam timing as I did not want to butcher main loom.
Old 05-14-2013, 08:04 AM   #5
Alvin@PCMofNC
Drives: 2010 IOM RSS
We normally cut a little spacer for the L99 Cam/Harness bracket and reuse it on the new setup. We normally also de-pin the wiring for the cam phaser just to clean it up a bit.
Alvin@PCMofNC is offline   Reply With Quote
Old 05-20-2013, 01:29 AM   #6
redredrage
redredrage's Avatar
Drives: 2010 Camaro SS manual all stock
Don't know why you would put a 454 in
redredrage is offline   Reply With Quote
Old 05-20-2013, 06:18 AM   #7
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
meshamey is offline   Reply With Quote
Old 12-23-2019, 10:22 AM   #8
05SilverStreak
05SilverStreak's Avatar
Drives: Black aSS 2011 - L99
Can you give a pic of one, or explain how you did this please.
A LOT of people say and post that they did this, (or know how to), but very little useable information is given.
Staying stock and loving it............
05SilverStreak is offline   Reply With Quote
Old 12-24-2019, 04:02 AM   #9
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
2 choices
Use adapter or replace connector
https://www.texas-speed.com/p-5686-v...r-harness.aspx
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
