Old 04-03-2024, 09:10 PM   #1
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Rear sway bar stiffening - ZL1 1LE
Been stock. Thinking to go out on the rear bar for the 15% increase in stiffness. Anyone tried this and have impressions? Looking for a bit more rotation in the turns.
wakespeak is offline   Reply With Quote
Old 04-06-2024, 02:48 PM   #2
Badmojo
aka BeastZL1
Badmojo's Avatar
It's easy to do at the track, so I would say try it out. I ran a couple of days with it in the softer setting to see if it would improve corner exit grip. I went back to the neutral (middle) setting and the car was faster.
If you get too much rotation, then you can always dial it back by lowering year tire pressure or adding rear negative camber.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 04-09-2024, 10:05 PM   #3
wakespeak
wakespeak's Avatar
Thanks for the video, looks easy to move.
Old 04-12-2024, 07:10 AM   #4
Checkmate1
Drives: Garnet Red / ZL1 1LE
It depends on the track you go to. With the softer rear setup, you will get more understeer that suits some tracks better. The softer rear does help put the power down better at the expense of rotation. It's essentially players choice.
#SAVETHEMANUALS
Checkmate1 is offline   Reply With Quote
