TireRack
Old 02-09-2023, 11:22 PM   #1
FerkLS3
Drives: 2010 2ss Cyber Gray
New short block scratches on cylinder walls after installing pistons
Hello, this was my first time gapping rings for a 416 thats going to see a lot of boost, I took my time grinding down all the rings with a stone and then deburring them and putting a slight bevel on them. after assembly I have some up and down scratches on the cylinder walls very light, the ones where gaps are are slightly more visible, but there are many smaller ones. none of them catch a nail and none of them can be felt at all you can just see them. pistons installed dry with a light touch of oil on skirts. Am I just being paranoid and is this normal for a freshly bored and honed block and new diamond pistons and rings? Thanks in advance for any input
FerkLS3 is offline   Reply With Quote
Old 02-10-2023, 01:23 AM   #2
Tommi
Tommi's Avatar
Drives: 2010 Camaro SS manual
I think those "scratches" mean nothing, but next time use lot of oil when installing pistons into cylinders.
2010 Camaro SS, LS3 + 6spd manual.
1975 Volvo 242, 357SBC + 6 spd manual.
1978 Blazer offroader with LS1, 1-ton axles.
Tommi is offline   Reply With Quote
Old 02-10-2023, 04:13 AM   #3
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Yes sir you need to oil the entire piston, rings, and cylinder walls when installing but I don't believe those scratches will hurt anything but definitely not good. Here's a picture of mine when assembling.
Name:  27 cylinder.jpg
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 02-10-2023, 07:19 AM   #4
FerkLS3
Attachment 1120215
Thanks for the responses guys. Just weird how this is on every cylinder. a light film was applied to each bore with my break in oil, everything moves so smooth. I removed a couple of pistons to see if skirts were rubbing and they are not, everything is perfect. I feel like im probably being to paranoid about this and I should just roll with it just wanted some other eyes on the issue.
Old 02-15-2023, 01:10 PM   #5
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Run it, Those are likely just superficial scuffs, it happens from time to time. Use a ton of oil stuffing the pistons into the cylinders, if in doubt always heir on the side of using more oil. It can also be caused by the ring compressor not being set tight enough and causing the ring gap to grab on the deck as it goes into the bore.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
416, engine, short-block, stroker
