02-19-2015, 06:07 PM | #1 |
Gas/OIL MIXTURE IN MY CATCH CAN!!!!!
I did an Oil Change with Mobil 1 full syn. dexos. about 1000 miles ago.
Did a check on my catch can. Since I installed the catch can the Oil has been a rich black color. Do my LOF changes frequently, It's tuned with the IPF, Has a CAI, Ported Throttle body and MRT V2. Since this past Oil change i did install a Vitesse Throttle Controller. Normally run the Sport settings was wondering if that could be why the oil looks so filthy letting to much fuel into the system. It Smells like Gas is mixed with my oil in the catch can.
[SIZE="100"] |
02-19-2015, 06:14 PM | #2 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
I'd say it's from condensation. If you still have it you can send it for an oil analysis. http://www.blackstone-labs.com/
2011 2SS/RS built 8/24/10
02-19-2015, 06:17 PM | #3 |
Drives: Chevys at the limit Join Date: Nov 2010
+1 for condensation. That's completely normal in the cooler months and there is usually a fuel smell to it regardless.
Best regards, Tyler 888-308-6007 |
02-19-2015, 06:18 PM | #4 |
Get rid of that catch can.. It's useless... I have had cars 30 years old that ran great with regular oil changes..
Currently have a 28 year old Ford with 147K on it with no issues..Unless you are competitively racing your car regularly like an animal, you do not need one.. |
02-19-2015, 06:33 PM | #5 |
I do still have it was going to take it to the dealer and show them. Just freaked out when i saw that. Thank you for the responses. Thinking about getting a 2012-13 SS once they release the 16. Don't want any issues before then.
[SIZE="100"] |
02-19-2015, 06:42 PM | #6 | |
Silver Ice
02-19-2015, 07:28 PM | #7 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
That looks like coffee with milk.
The PCV was designed to work without a catch can. This is the kind of stuff the engine would normally get rid of through combustion by blowing it back through the intake. |
02-19-2015, 07:37 PM | #8 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Normal
This is what my truck looks like in winter then goes back to a black color Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
02-19-2015, 07:43 PM | #9 | |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
So, if anything needs a catch can it's the direct injected V6. The LS3 and L99 probably would be perfectly fine without one, especially with all the detergents in fuel these days. It certainly doesn't hurt anything though.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
02-19-2015, 07:46 PM | #10 |
Silver Ice
Id rather not risk it. Cost me around $100 for a piece of mind and I dont have milk in my intake manifold. I check every oil change, clean as a whistle. Yours?
02-19-2015, 07:59 PM | #11 |
02-19-2015, 08:02 PM | #12 |
Silver Ice
Im not trying to give you a hard time. Its just that its time tested and proven on this forum to help keep our valves and intake manifolds clean(er). Ive been here for a only little over a year and I've seen it time and time again. Im at 52k miles to your 12k miles. Check it at 20, then 25. You'll be singing a different tune, but I hope Im wrong.
02-19-2015, 08:04 PM | #13 |
Silver Ice
Btw my engine went before I had a catch can, and the valves and IM were horrible and the tech noted this to me. Related, probably not. But
02-19-2015, 08:06 PM | #14 |
SS
interesting walnut blasting I've heard or that on industrial gas turbines also, plus rice both combustible residues I guess
catch cans the new tail light lol I have one too! the colder climates have always cause the greasy deposits due to colder starts and condensing exhaust exhaust. Most of the exhaust comes from chemical combinations of the fuel and oxygen. When a hydrogen-carbon-based fuel (like gasoline) burns, the exhaust includes water (hydrogen + oxygen) and carbon dioxide (carbon + oxygen). But the exhaust can also include chemical combinations from the oxidizer alone. If the gasoline is burned in air, which contains 21% oxygen and 78% nitrogen, the exhaust can also include nitrous oxides (NOX, nitrogen + oxygen
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
