06-27-2017, 09:24 PM | #1 |
Drives: 2011 LS Camaro Join Date: Mar 2011
Emergency... trunk issue :(
Was doing header work and disconnected the negative terminal. Left the spare tire at a 45 degree angle and i have a huge sub enclosure behind it. Brother closed the trunk accidently and now I can't open the trunk or better yet start my car.... any tips? Will jumper cables in the engine terminals allow me to pop the trunk?
Exhaust: Magnaflow catback/x-pipe, Injen SRI, BBK Headers w/ no cats
Suspension: BC BR Coilovers Cosmetics: ZL1 front conversion, AAC plasma afterburners 2.0, GFX rear, Interior: AAC red footwells, ZL1 shifter boot/knob, suede center console |
06-27-2017, 09:26 PM | #2 |
Drives: Miss Con Ception Join Date: Aug 2016
Yes. No problem. You can even use a battery charger.
Are you bigger than your brother?
2011 1SS/RS LS3 CGM
06-27-2017, 09:36 PM | #3 |
So jumper cables should be good? Yeah, i'm 5'10 160 and he's 5'8 120
06-27-2017, 10:57 PM | #4 | |
The smart ones today know how much and when to charge.
2011 1SS/RS LS3 CGM
06-28-2017, 01:20 AM | #5 |
Drives: 2009 ZR1 Join Date: May 2010
Pull the back (vertical part) of the rear seat down, crawl into the trunk and pull the T shaped handle to release it manually. Find someone small and give them a flashlight.
Since the negative terminal is off the battery, hooking jumper cables up won't allow you to open the trunk. The whole system is ungrounded. |
06-28-2017, 02:34 AM | #6 | |
You don't need to crawl into the trunk. There is a terminal covered with a red plastic and an uncovered terminal on the left side of the engine bay. The one with the cover is the positive, with a Plus sign on it, the uncovered one by the air cleaner is the negative (ground).
2011 1SS/RS LS3 CGM
06-28-2017, 06:18 AM | #7 |
Drives: 2014 2SS/RS Join Date: Dec 2014
The Camaro Engineers planned for just such an emergency and provided a manual trunk lid release on the underside of the lid partly for that reason.
Just work the handle loose and let the cable hang down, then once the handle is free from the lid, pull down.
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
06-28-2017, 07:28 AM | #8 |
Drives: 2011 camaro ss convertible Join Date: Oct 2015
Im assuming you can't crawl into the trunk through the back seat due to way you left the spare tire ? Either way all you have to do is use jumper cables through the terminals under the hood to have power and just use the button to open the trunk, you dont have to start the car like that just to open the trunk
06-28-2017, 07:49 AM | #9 | |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
I am not sure if coupes have the same as convertibles but in mine there is a key cylinder in the back seat on the drivers side. You put the ignition key in it and turn to the left to open trunk.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
06-28-2017, 08:41 AM | #10 |
Drives: Camaro Join Date: Mar 2013
The entire back seat comes out in 5 minutes. Lots of room to do what you need.
06-28-2017, 08:46 AM | #11 |
Sub enclosure covers entire trunk so I can't just climb into the trunk. Plus in the OP the spare tire was blocking me from manuvering the subwoofer. Jumper cables worked. Thanks guys.
06-28-2017, 09:09 AM | #12 |
Drives: 2015 Chevy Camaro 2LS Join Date: May 2017
super surprised the cables worked with negative disconnected!
now we know! |
06-28-2017, 11:30 AM | #13 | |
Drives: 2014 2ss/rs Join Date: May 2012
The car was not grounded right up until he put the jumper cables on the negative terminal... this grounded the car through the cable to the other vehicle's ground. I would not suggest trying to start a car like this, but it will hold enough current to pop the trunk. |
06-28-2017, 12:38 PM | #14 | |
