dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 07-25-2013, 04:35 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
Aluminum Driveshaft
What brand is everyone using? Who's got the best deal around? Looking to get 1 soon. Thanks
Craig B is offline   Reply With Quote
Old 07-25-2013, 05:32 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I always here good things about the driveshaft shop. They have shafts ranging from $650-$1400.
http://www.driveshaftshop.com/domest...maro/2010-2011
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 07-25-2013, 05:41 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
We recommend DSS as well. Feel free to call, PM or email us with questions or pricing.
Best regards,
Tyler
888-308-6007
JDP Sales is offline   Reply With Quote
Old 07-25-2013, 05:48 PM   #4
axis
Search Ninja
axis's Avatar
For the record, JDP's prices are right inline with the prices listed at DSS. I'd go with them for the shear fact that they are a C5 vendor and they are just good guys to deal with. They will also make sure you're 100% satisfied with your purchase.
Halltech CF 102 fed
Old 07-25-2013, 06:44 PM   #5
mhdragradial
Drives: 2011 camaro
dss is best for parts and customer service
mhdragradial is offline   Reply With Quote
Old 07-25-2013, 06:56 PM   #6
JDP Sales
JDP Sales's Avatar
Thanks for the kind words Axis!
Indeed. DSS has always been right on the ball for us with warranty claims and they definitely take care of their customers!
Best regards,
Tyler
888-308-6007
Old 07-25-2013, 06:56 PM   #7
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
I have a DSS coming in soon.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 07-25-2013, 08:25 PM   #8
tanur420
would it make a noticeable 1/4 time upgrading to alum drivesht?
tanur420 is offline   Reply With Quote
Old 07-25-2013, 08:32 PM   #9
Craig B
Craig B's Avatar
Drives: 2013 1LE
I'm thinking that it wont hurt.
Old 07-25-2013, 11:50 PM   #10
axis
Search Ninja
axis's Avatar
Depending on where you are in the modding process, that $650+ might be better spent elsewhere. A driveshaft isn't high on the "must need" list unless you're making some serious power.
Halltech CF 102 fed
Old 07-26-2013, 12:08 AM   #11
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
Not thread jacking but at what HP level should you upgrade axles driveshafts and etc.?
Nightmare2012 is offline   Reply With Quote
Old 07-26-2013, 12:29 AM   #12
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
I'm not of the same mindset as the people who say you're fine. It's more of a "get it done" thing for me. If you're pushing 500HP, then start expecting things to break. You can fix it first, or after it breaks... your choice. I hate being stuck... so I would choose fix it first .
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 07-26-2013, 05:03 AM   #13
axis
Search Ninja
axis's Avatar
I agree but we have no idea what the OP has, as far as mods go. That's why I said it depends on where he is in the modding process. $650+ is a large chunk of change that could be spent towards a cam, gears, headers, ect.
Halltech CF 102 fed
Old 07-26-2013, 05:30 AM   #14
Craig B
Craig B's Avatar
Drives: 2013 1LE
If you can dead hook with slicks or drag radials, it might just be needed. Even more so with a manual trans. Keep in mind 3800 lbs + driver.
