03-12-2024, 01:06 PM | #15 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
If you want to confirm you have the lockout try shifting into second at 1200 rpm. If you’re giving too much throttle before shifting it won’t lockout so only lightly accelerate to 1200 rpm. Two conditions have to be met in order for the lockout to activate. 1) Throttle has to be at X percentage or lower before you let off to shift. 2) You have to be below a specific RPM
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
03-13-2024, 04:21 PM | #16 |
It's in the hole!
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE Join Date: Apr 2011
Thanks for all the tips guys. Like I said this is my 3rd car with the 6060 and I also had the T56 so I'm no stranger to the 1st to 2nd when cold issues. This one is just different, there is no grind ever but sometimes it just doesn't go all the way into 2nd gear and that's when it will pop out when you let the clutch out. I'm getting better at feeling what's going on and avoiding problems. I think it's a synchro thing that is preventing the gears from aligning and meshing. Soon as I get a chance I'm going to try Royal Purple, it that doesn't work then it will be Redline D4 which I have used in the past.
03-13-2024, 05:08 PM | #17 |
Drives: 2024 Camaro 1SS M6 Join Date: Nov 2023
03-13-2024, 09:34 PM | #18 | |
Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
I'm still going to install a skip shift (which just arrived in the mail today actually). It is very annoying the times I forget to shift outside the window and activate it. I look like a first time driver while I wait for the lockout to deactivate and finally shift to second (I hate lugging the engine so I usually wait rather then shift to 3rd) |
03-13-2024, 10:03 PM | #19 |
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
If you don't drive it like a Pinto from 1978 and shift the trans from 1st to 2nd at 23 mph or above 3k while doing a 2 part pull into gear. It should be fine. Ive never had the trans lock me out or force me from 2nd to 4th. This TR 6060 seems to like a 2 part pull into the next gear. The only time I've had my trans pop out of gear was when the the outside temps were cool and I didn't pull the shifter through the gate. I beat on this car every time I drive it and redline multiple gears each time I take it out on the street or on the track.
