Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 07-10-2012, 06:37 PM   #1
ZL1 Brian
ZL1 Brian's Avatar
Drives: 2012 Camaro ZL1
Launch Control
Does anyone know how to use the launch control? I have watched 2 You Tube videos on this and Ifollowed how they did it and my car just wont do it. One video says to put it in mode 4 for the street and non slicks, and the other was only using mode 5. I tried them both. When in the launch mode your supposed to put the peddle to the floor and the RPM's are supposed to stay between 3,00- 4,00. I cant get it to do this, it just winds all the way out. Any suggestions? Im taking it through the quarter mile on Friday and would sure like to have this feature working.
ZL1 Brian is offline   Reply With Quote
Old 07-10-2012, 08:04 PM   #2
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Stop, wheels straight, performance mode, clutch in, floor it. Revs should rise to rev limit, then drop to around 4k. Lift your foot off the clutch, don't side step it. Hang on.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 07-10-2012, 08:13 PM   #3
Blueclyde
Drives: 2023 ZLE
Very important to follow all of the steps above. You have to put the accelerator all the way to the floor rather quickly. I'll admit it is a bit nerve racking but that's how it works. If you are gently on the throttle it will not work. Put it to the floor.
Blueclyde is offline   Reply With Quote
Old 07-10-2012, 08:19 PM   #4
ZL1 Brian
ZL1 Brian's Avatar
Are you supposed to have it out of gear before putting it in launch mode? I've had it in first gear when I was trying it.
Old 07-10-2012, 08:38 PM   #5
Blueclyde
Drives: 2023 ZLE
First activate PTM. Push in clutch. Put in 1st. Accelerator pedal to the floor quickly.
Old 07-10-2012, 08:43 PM   #6
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
On Chevy.com, they have a video on all 5 PTM modes including Launch Control. The vids are very informative.
2SSJIM is offline   Reply With Quote
Old 07-10-2012, 08:49 PM   #7
OldScoolCamaro
Drives: Camaro's, always have, always will.
There are three switches on the center console. From left to right: Tour, Sport, and Stabiltrak. Depress the stabiltrak switch twice. Two yellow lights will activate on the right gauge cluster. The driver info center directly above the steering wheel will show you are in sport mode two with PTM on. Depress the sport switch to go up to mode 3, 4, and race mode 5. Depress the tour switch to move back down though the scale. You can use launch control in any mode of tour or sport only with PTM activated. Launch control can only be used when you depress the stabiltrak switch TWICE and enter the PTM mode. In PTM hold and keep the accelerator to the floor and keep it planted there. The motor will bounce off the rev limiter, then find it's happy medium RPM depending which PTM number you are at. It's roughly around 4K RPM that the motor will hold at. With your foot on the clutch, in first gear, with the steering wheel straight, slide your foot off the clutch and launch. You will have a smooth, controlled, approximately 60 foot burnout then progress thoughout first gear.
In Scott We Trust...all others must show proof.
OldScoolCamaro is offline   Reply With Quote
Old 07-10-2012, 09:36 PM   #8
Oneslowz28
Drives: 2012 Camaro ZL1 #1265
i think this saved me from reading the el-manual
Oneslowz28 is offline   Reply With Quote
Old 07-11-2012, 01:26 AM   #9
wyoming zl1
wyoming zl1's Avatar
Drives: 2012 ZL1 #1372
I have just recently gotten my car broke in and i have not had the oppertunity to try the lanch control yet, but i have tested it and it does hold the r's at about 4 grand when i go into the lanch setting. My question is around the no lift shift. How are you all working the clutch? Do you press it all the way on every shift, or only part way?
wyoming zl1 is offline   Reply With Quote
Old 07-11-2012, 02:38 PM   #10
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
What do you mean by "slide" your foot off the clutch"? release the clutch slow and as fast as possible?
cybercoaster is offline   Reply With Quote
Old 07-11-2012, 02:41 PM   #11
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
No lift shift means you leave your foot on the throttle, and use the clutch as normal. This keeps the boost high on the supercharger. You'll notice it when done correct.
I just release the clutch in a faster motion than normal. That's all I have done when I was at the track a few weeks ago.
armysig is offline   Reply With Quote
Old 07-11-2012, 02:42 PM   #12
IcePick06
IcePick06's Avatar
Drives: '12 AGM ZL1 (SOLD); '07 Ducati 1098
I've done it both ways but found it to be a little bit faster only pressing the clutch in half way. For whatever reason the Camaro has a really narrow "FRICTION" zone in the clutch, much more narrow than any other car I've driven. Therefore, the clutch engages about about 1.5-2 inches of pedal travel so that's all you really need to use when either regular shifting or no lift shifting. It will require some practice and mental adjustment at first with the no lift and you will get a "surge" of power as the torque is held up when you shift just like you do when POWER shifting...since that is essentially what you are doing anyway
IcePick06 is offline   Reply With Quote
Old 07-11-2012, 06:58 PM   #13
OldScoolCamaro
Sorry for any confusion, it was a matter of word choice on my part. Release the clutch anyway that you deem appropriate. It won't matter to the tranny, or driveline, as long as you have your foot matted to the floor on the gas. I guess dump the clutch would have been a more appropriate word choice....
Old 07-11-2012, 10:47 PM   #14
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
So when you release the clutch on launch you leave the throttle pinned and let the traction control initially slip, and catch traction on its own?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
