04-18-2024, 07:26 AM | #1 |
Will it spin?
This may be a stupid question but not 100% sure, so here goes. I want to put white letters on my tires. With a limited-slip rear end if I jack up the rear on the driver's side with the passenger side on the ground can I spin the tire off the ground?
04-18-2024, 07:33 AM | #2 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I'm thinking, not without some effort. You have to overcome the friction plates that make it a LSD diff. But I could be wrong!
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
04-18-2024, 07:35 AM | #3 |
used to love that look back in the 70s,but i think its kind of dated now unless youre driving a 60s musclecar...
04-18-2024, 07:55 AM | #4 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
It should spin with a bit of effort.
04-18-2024, 07:57 AM | #5 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
You would have to turn it hard enough for the carrier's internal clutches to slip.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-18-2024, 08:27 AM | #6 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
You could jack up the whole rear end and just spin both wheels? Or use the e-brake to turn the wheels as needed to add your letters?
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
04-22-2024, 09:07 AM | #7 |
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
Im just gonna take my wheels off when I finally decide to put my tire letters on. Theyve only been in my garage for over a year and a half. Im probably gonna need new tires before I put them on lol. guess im buying the same tires again so i dont waste those letters.
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads |
