11-22-2017, 10:22 PM | #15 |
The issue is never going to be fixed until GM fixes the TCM tune. Guys are fixing the shudder issue using the original TC and fluid by tuning out the TCC slip. Also turning off AFM helps. There is absolutely too much going on in the TCM...you have the converter locking almost every gear, AFM kicking in, then the TCM commands the TC to slip for AFM....all for 1mpg of increased fuel mileage. It's a bunch of horse shit.
2016 NFG 1SS A8
11-22-2017, 10:40 PM | #16 |
Drives: 2016 Camaro 2SS/RS Join Date: Oct 2008
This shudder is the only problem my Camaro has had. I took it into the dealer and they simply replaced the torque converter. My only fear is that it will eventually happen again.
2016 2SS: Silver Ice, A8 Auto, Adrenaline Red, Black Rally Stripes, and Black bowties.
My Journey..... 1100 Status - 08/17/2015 : 2000 Status - 09/28/2015 2500 Status - 09/29/2015 : 3000 Status - 09/29/2015 3000 Status - 10/19/2015 TPW 11/9 3800 Status - 11/04/2015 Seq: 122808 4300 Status - 12/17/2015 (Charlotte, MI) 4200 Status - 01/08/2016 4800 Status - 01/14/2016 5000 Status - 01/19/2016 6000 Status - 01/20/2016 |
11-22-2017, 10:51 PM | #17 | ||
Drives: X-15 Velocipede Join Date: Mar 2008
Haven't heard of the dreaded "shudder" in the A10. Quote:
Have you experienced this tune? What's the difference in driveline shock and driving experience? If driveability and shock are acceptable, that's a great way to "fix" the shudder. Not to mention cut down the fluid and circuit contamination from slipping what was a LOCK-UP clutch.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
11-23-2017, 12:06 AM | #18 | |
2016 NFG 1SS A8
11-23-2017, 12:58 PM | #19 | |
Drives: 2016 camaro ss Join Date: Oct 2010
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
11-23-2017, 01:05 PM | #20 |
I had AFM tuned out and the shudder was gone.
Prior to that if I manually shifted the car and kept the RPM's above around 2k when cruising there wasn't any shudder. The problem is when it's dumping you into 8th gear going 45 and shutting off half the engine. They can polish this turd all day long, until they fix the tune on the trans it's never going to get better. |
11-23-2017, 01:52 PM | #21 |
Drives: 2016 SS/2SS Convertible A8 MRC NPP Join Date: Jan 2015
I had the same shudder problem with my 2016 SS A8. The trans also slipped on hard acceleration (cost me a race with a Mustang). The first service call they flushed the trans after I begged them to replace the converter so I would not have to come back. Shudder was noticeable the day I drove it home. Service writer told me I had to put 500 miles on it before they would look at it again (service manger later said only 200 miles needed). I drove it from South Florida to The Dragon in NC. Three-thousand miles later I took it back in. The service manager took a ride with me and said that seven letters have come from GM about this issue and flushing the trans was just putting a band aid on the problem. They replaced the converter and problem solved for now.
11-23-2017, 02:33 PM | #22 | |
Drives: HB 2SS Join Date: Apr 2017
11-23-2017, 07:26 PM | #23 |
It's the TCC slip tables as I already mentioned. EFI tuning discovered this when HP tuners 3.7 beta was released. There is a thread ongoing about it. Some have been able to fix their shudder issues by zeroing out these slip tables.
http://www.camaro6.com/forums/showthread.php?t=510599 http://www.camaro6.com/forums/showpo...&postcount=278
2016 NFG 1SS A8
11-23-2017, 07:50 PM | #24 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
yup I zero'd all of those tables out
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
11-24-2017, 08:40 AM | #25 | |
Drives: 2017 2SS A8 NGM, 2012 Yamaha FZ8 Join Date: Jan 2017
Like other mentioned, mine is not in V4 mode when this happen. It's always in V8 with the transmission in 7th or 8th gear. |
11-24-2017, 08:51 AM | #26 | |
11-24-2017, 10:37 AM | #27 |
In the same section where I posted those links...step out of the general discussion section and expand your horizons.
2016 NFG 1SS A8
11-24-2017, 11:47 AM | #28 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
I had the shudder at about 17K miles. Took it in to the dealership, had the 3X trans fluid flush done. Im now right around 20K miles. Issue has not recurred. Car shifts great now...big improvement in overall driving experience!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
