Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 08-27-2013, 09:06 PM   #1
mc_acoustic
Drives: 2010 1LT Limited Edition Camaro A6
What the heck happened with my auto?
I was hoping this issue would go away....
This is for an automatic.
But it shows to still be an issue. Here is what happens.
1. I'll be at a stop sign. (THIS IS IN MANUAL/SPORT MODE)
2. I'll rev up (Nothing crazy just to get going)
3. My car REFUSES to shift for some reason
4. My rpm gets to 5000 at like 20-25 km an hour in first gear
5. For some reason my car activates my paddle shift.
6. Now at this point if I dont shift myself my car would rev to the limit.
Why is this happening? I do have trifecta tune built around the nitrous timing.
I have to figure this out before It blows my engine beacuse I am running nitrous now.
Any idea?
2010 Camaro Synergy Green Edition V6/A6: Cold Air Inductions Intake, Trifecta tune, BBK long tube headers and Hi flow cats, MRT V1, Ported Throttle Body, Stage 4 Ported Intake Manifold (MACE), Black Ice-olator Intake Manifold Spacer, Plenum Spacer, Nytrex Triple Threat Nitrous.
mc_acoustic is offline   Reply With Quote
Old 08-27-2013, 09:19 PM   #2
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Sports mode tends to hold your rpm at a higher range before shifting.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 08-27-2013, 09:20 PM   #3
kevint
Drives: 2013 1SS
Any idea?
If it is in SPORT mode, then it will shift automatically. If it is in MANUAL mode, then you have to use the paddles. The DIC will display "S" or "M1, M2, etc.," depending on if it is in SPORT or MANUAL, respectively.
You drive with your nitrous system armed all the time?
kevint is offline   Reply With Quote
Old 08-27-2013, 09:39 PM   #4
mc_acoustic
Yeah true but I know when it shifts, usually shifts at 2000 rpm. Like I said before it was at 5000 rpm and it went into paddleshift mode and was telling me to shift for the car. and I was going up SLOWLY I was NOT slamming my foot down.
I was in sport mode and it forced itself into manual mode I wasnt touching the paddles at all.
It said "S" then out of now where it went to "M1" without touching paddles.
And no, the system is not armed all the time.
Old 08-27-2013, 10:28 PM   #5
CamaroKevin
CamaroKevin's Avatar
Drives: 2011 Chevy Camaro 2LT RS SIM
I think I know what OP means....
I've put my auto trans in M (Sport Mode) without activating the paddle shifters, and the car seems like it can't shift. Almost as if it's holding the Rev in one of the gears way longer than I should.
I'm aware the rpms are higher in S mode, but like I said, feels stuck in gear.
Is that what you meant?
CamaroKevin is offline   Reply With Quote
Old 08-27-2013, 10:46 PM   #6
mc_acoustic
Right on the nose. Have you figured out why its happening?
Old 08-27-2013, 10:50 PM   #7
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Have never experienced that. However, i have experienced the old stuck in gear when your in the twisties in S mode. It actually does get flaked out due to the yaw sensors and the nannies. depending on how your in the throttle and how much roll you have going on. At that point you gotta paddle out of it. In this scenario though it does not show it in manual mode but rather just stuck in a low gear with high revs. I can make this happen at will by getting on it hard then braking hard and then hitting it again good out of the turn. Too much roll and your stuck in gear revving to the moon.
I can eliminate most of it by going into comp mode or with nannies off.
My tranny has been well tuned with the pressure notched down with quick hard shifts. It cut out some of it but not all for sure.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 08-27-2013, 10:52 PM   #8
Biscuitpie
Biscuitpie's Avatar
Drives: '11 Cammed LS3, '14 Scion FRS
Ask your tuner.
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP
Biscuitpie is offline   Reply With Quote
Old 08-27-2013, 10:58 PM   #9
CamaroKevin
I haven't yet ... It doesn't happen too often, but has happened at least a few times. I still have bumper to bumper warranty, so I may have them take a look and see if it's anything wrong.
It only happens in M, not D. Must be the car mixing up S and M modes or something?
I'll PM you if I hear anything from Chevy next time I'm in for service.
Old 08-27-2013, 11:02 PM   #10
mc_acoustic
My tranny has been well tuned with the pressure notched down with quick shifts. It cut out some of it but not all for sure.
Waaaaait! My nannies are all off because I love full throttle.
And Now that I am thinking of it... I put my foot on the gas, then braked for a second (Hesitated) then put my foot down again.... I wonder if I confused the car....
Is this possible?
Old 08-27-2013, 11:07 PM   #11
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Is this possible?
Yes it is. This tranny does not like you getting on it then braking and getting back on it quickly. Especially in curves or turns.
Old 08-27-2013, 11:11 PM   #12
mc_acoustic
ANNNND. every time its happened.... was at a turn...
Question answered thank you!
Old 08-27-2013, 11:18 PM   #13
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
The car is tuned from the factory to keep the revs up high in Sport mode when you are driving aggressively because it believes you are road course racing. That is Sport mode and is normal.
What isn't normal is it switching over to paddle shifting when not touching the paddle buttons. I have no idea if a car can be tuned like that (By mistake I would hope).
Talk to your tuner.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 10-18-2013, 10:15 AM   #14
shellscamaro
Drives: 2013 Camaro RS
Manual Transmission
Did you get any results on your issue?
shellscamaro is offline   Reply With Quote
