02-01-2018, 11:38 AM | #1 |
Instagram @bdubil
Window trim detail suggestions
Looking for suggestions on how get rid of this crap on the window moldings. (see pics) Any one dealt with this before?
So far I've clay bared the molding and then tried Meguiars ultimate black plastic restorer & it hasn't helped much. Didn't find much on youtube for over the shelf products to help. Any suggestions are appreciated. Thanks
Brian | Summit white 2012 2SS
02-01-2018, 11:41 AM | #2 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
It's a fungus, I used Clorox on mine and got most of it, BUT i would not recommend it.
yep makes since, you from Florida.
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
02-01-2018, 12:19 PM | #3 |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
i would try Mr. Clean Magic Eraser. try a small area... put down tape near your car paint so you don't scuff the paint. these pads are actually do super light sanding... but are amazing.
02-01-2018, 12:42 PM | #4 |
Instagram @bdubil
Thanks
02-01-2018, 12:44 PM | #5 |
Instagram @bdubil
Thanks for the suggestion
02-01-2018, 12:44 PM | #6 |
Glad you mentioned this as I was planning on just replacing the plastic, but I'm going to try the cleaning products first
02-01-2018, 01:34 PM | #7 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
50/50 mix of bleach and water. Put Adams VRT on it once you get the crap off.
2011 2SS/RS built 8/24/10
02-01-2018, 01:35 PM | #8 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
I would either try a Mr. Clean eraser or some Simple Green to clean it off. If that doesn't work, I would try a trim restorer like ArmarAll's OutLast. Once you get it cleaned up, I'd wipe the trim down with Trinova UV Protectant or other protectant. I've used Trinova for a couple of years now and keeps all the trim looking like new. You can find it on Amazon ....
https://www.amazon.com/TriNova-UV-Pr...restorer&psc=1
02-01-2018, 02:23 PM | #9 | ||
Instagram @bdubil
02-01-2018, 04:32 PM | #10 |
Do you mind updating us if with your results? No pics necessary, just your opinion would be fine. I'm curious if a magic eraser works well, seems like it may. The last time I restored the trim on a vehicle, I ended up sanding it with fine sandpaper, it got rid of the fungus but was obviously not as smooth as it was before.
*SOLD* 1997 Camaro L36, Arctic white, manual, stock af |
02-01-2018, 04:38 PM | #11 |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
I have hard plastic for a rub rail on my boat that looked like that. It made it look really bad. I dont know if you want to try it on a car but nothing would take it off. Black to black or any cleaning product. If you are going to replace it anyway give it a try. I used lacquer thinner on a rag. I think it might have melted the surface a bit but it came out like new. I do it about every 4 years and it does not change the texture at it at all.
02-01-2018, 05:00 PM | #12 |
Someone on a Tacoma forum had good luck with convertible top cleaner. Haven't tried it myself but it may also be an option.
https://www.tacomaworld.com/threads/....115696/page-2
02-01-2018, 06:48 PM | #13 | |
Drives: 2011 SGM 1SS A6 & 2014 SW 2SS/RS M6 Join Date: Jul 2014
02-01-2018, 08:46 PM | #14 | |
Instagram @bdubil
supashane - for sure, I'll post an update with the results. Going to work on it in a day or 2.
