08-13-2014, 09:23 AM | #43 |
Drives: camaro zl1 Join Date: May 2014
I had a Boss 302 previous to this car and the zl1 is much smoother. My guess is the magnetic ride and irs plays a big part.
08-13-2014, 09:49 AM | #44 |
Drives: 328xi, ML400, ZL1 man. 2013 Join Date: Aug 2012
for me the tire pressure made a huge difference. Ride became smooth with just a small .5 to 1 psi change. I am running 31 psi cold and it was night and day from 32 to 33 psi.
08-13-2014, 10:10 AM | #45 |
Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
The ride is great! The car feels like it's performing normally. The noise in the passenger side strut is gone and the car absorbs pretty much all the bumps in the road. My only other issue is rock chips but I guess investing in some xpel should do the trick.
08-13-2014, 11:19 AM | #46 | |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
🔺22 RS E TRON GT
🔺21 Model S Plaid |
08-13-2014, 01:12 PM | #47 | |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
I like it even more after I lowered my car. I want and need the feedback the car is offering. Who wants a soft plush sloppy sedan like suspension in a high performance car? Even 1.25 inches lower the car rides well over bumpy roads. I normally leave mine in sport. If the road is bumpy I switch the setting to tour and no problems. Maybe your roads are in worse shape than here in California? |
08-13-2014, 10:14 PM | #48 | |
Drives: GM Vehicles Join Date: Jun 2010
Thanks for your update! It's great to hear that the dealer addressed your concerns and now service is complete. Please let us know how the vehicle operates moving forward and don't hesitate to message us if any additional questions or concerns arise. William R. Chevrolet Customer Care |
08-14-2014, 08:16 AM | #49 |
Drives: Cyber Grey 2LT RS Coupe Join Date: Feb 2011
Maybe my tires are also the wrong psi, but I use the gauge when I fill them so it can't be that.
08-14-2014, 11:37 AM | #50 |
08-15-2014, 02:54 PM | #51 |
It's that little pen thingy you stick inside the tire.
08-15-2014, 02:55 PM | #52 |
Hot or cold pressure readings. How could I tell if that little thing is reading hot or cold pressure?
08-15-2014, 02:56 PM | #53 |
All it says on it is kap or psi. I read from the psi side.
08-15-2014, 04:00 PM | #54 |
Drives: 2014 ZL1 Join Date: Apr 2013
Some of those pen pressure gauges are ok, others are cheap junk, not sure how accurate yours might be, you can compare to the DIC reading.
It reads the pressure at the time you take it. If you've been driving, it will be the hot pressure. First thing in the morning will be the cold pressure. Most of the specs you read are generally for cold pressures, if you are matching those pressures after driving a while, you probably are too low. |
