10-07-2023, 06:28 AM | #1 |
Ranger Clutch Line Flush Method
Does anyone know for certain if the Ranger flush method flushes all the way to the slave or only to the master?
10-07-2023, 02:55 PM | #2 | |
GPI Sales Consultant
If so, I think you get a limited amount of flush on the system as a whole. Definitely better than nothing, but I think using a remote bleeder is the way to go, because you draw off fluid at the "end of the line" while continuously adding fresh fluid from the other end, so you can get a more complete flush.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
10-07-2023, 06:25 PM | #3 | |
If it wasn’t so dam difficult to get to the bleeder I would add a remote bleeder which I will do when the time comes that I have to because of pedal problems or to replace the clutch. Until then I’ll continue to use the Ranger method via my remote reservoir even if only cleans a portion of the system’s fluid which I guess is better than never introducing any clean fluid into the system. |
10-07-2023, 08:45 PM | #4 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
I do this on my C6Z. Unfortunately it's not full proof. My master and slave took a dump @ 38k miles (bought it with 28k miles). It helps alleviate any future issues, but as I mentioned not full proof. Luckily for me, I ended up getting my money back from GM since they had a TSB after the fact.
What acammer said... install a remote bleeder.Helps a lot, and it'll make sure the whole system is "clean"
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
10-08-2023, 01:46 AM | #5 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I'm wondering if this improved version would work on our Gen 5s.
Note: Maybe one of you tech savvy guys can download the link.
10-08-2023, 08:24 AM | #6 | |
https://www.corvetteforum.com/forums...er-method.html I guess if there's no remote bleeder, this is a good option.
10-08-2023, 07:13 PM | #7 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
better off jacking the front end up, crawling under there and letting the bled fluid run down your armpit. Remote bleeder is well worth it if you are pulling the trans.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
10-08-2023, 08:42 PM | #8 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Is it possible to install the remote bleed with trans in the car? I have one sitting on the shelf. Maybe using a inspection camera or something to see what you are doing.
Can you use the factory bleeder with trans in the car? I know it is tight.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
10-09-2023, 05:20 AM | #9 | |
10-09-2023, 07:06 AM | #10 | |
10-09-2023, 07:17 AM | #11 | |
10-09-2023, 06:52 PM | #12 |
Reading that thread it doesn't appear to be to bad of a job in the car.
10-10-2023, 04:55 AM | #13 | |
Drives: Camaro Z/28 Join Date: Sep 2023
10-10-2023, 07:28 AM | #14 |
If I had a way of getting my car high enough off the ground I might try it, BUT I’d be worried that because you’re screwing the bottom of the bleeder into the slave blindly and just by feel that you may think you have a good connection when in reality you stripped the connection threads
