11-12-2023, 09:13 PM | #15 | |
Drives: 18 Camaro 2SS Join Date: Jul 2019
11-13-2023, 06:45 AM | #16 | |
Hot Camaro
You see where I'm going with this? Call GM Customer Service and open a case. Sorry about the family drama stuff - I can relate. |
11-13-2023, 09:27 AM | #17 |
I would get quotes from independent shops.
I also think ember's idea is valid. With quotes in hand maybe you can get GM to give you a 50% discount on the labor given your history with the problem. then you can pick the shop where you want the work done. |
03-18-2024, 07:15 PM | #18 | |
I ask as I am now in a similar situation. I had the triple flush at 10k miles (last one i had to tell the dealer to change the filter because according to them, the TSB didnt say to change it; so take a shower and put dirty underwear and hope you dont smell). Now after a long time and at 31k miles it came back again with hard shifting. Only because of time it is out of warranty and the cost of replacing the TC is something i’m dreading in my current situation. Also, on another subject, if I decide to replace the TC with a CircleD TC with stock stall (part number 24-07-05-1A) do I also need to replace the flex plate or no? Thanks for any advice on both questions
2018 Camaro 1SS | BBK 92mm TB | GPI Ported LT1 Manifold | ColdAirInductions CAI | Granatelli Wires and MSD coils | Mishimoto Catch Can | GMP Black Strut Tower Brace | NPP Exhaust and 2nd Cat Delete | Recaro Seats | GM Stainless Sport Pedal Kit | GM Carbon Fiber Shift Knob | Deck Lid Spoiler with Wicker Bill | Smoked Sequential Taillights | Smoked Third-Brake Light | 1LE Front Splitter/Satin Black | ZL1Addons Splash Guards
2015 Camaro SS/RS (Sold) |
03-18-2024, 07:33 PM | #19 |
In my opinion, if you have to change a torque converter is because it was abused or neglected, and it’s very hard to abuse it. Number one rule do not flush!!! always dump and change. Friction clutches, valves do not like a flush after complacency with amount of break in or abuse! It’s kind of like the rest of us set in our ways
03-18-2024, 07:54 PM | #20 |
Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
...Am I the only one who thinks this sounds like total BS?
I get caliper slides and rotors corroding, and other issues that can happen from sitting.. But I've never heard of rotors warping from sitting. Is this a thing? |
03-18-2024, 08:03 PM | #21 | |
Thank you Al Oppenheiser!
+1 on the recommendation for an independent shop. Ask around at a local drag strip and see where they take their broken transmissions.
18Black2SSinAZ, what's more likely is uneven pad transfer while stored -- happens frequently with the stock Brembo pads if brakes were "put up wet." In extreme cases (put away wet AND hot) they can bond together to the point where the car will be hard to move and you'll hear a bang when they break free loud enough to sh!t your pants thinking you just broke the car. Uneven pad transfer to the rotor can cause stick-slip vibration when in motion. So put a dial gauge on them to verify the runout. If pad transfer is confirmed, then sand all contact surfaces (pads and rotors) with 400 grit and spray-n-wipe well with brake cleaner. Then re-bed the brakes per the performance manual. Last edited by Gunkk; 03-18-2024 at 08:14 PM. |
03-19-2024, 11:52 AM | #22 | |
