10-27-2020, 04:26 PM | #1 |
NY Football Giants YAY!!!
Drives: 2011 LS Join Date: Aug 2010
Timing Chain Replacement at 97,000 miles
I thought the timing chain was supposed to last the life of the engine. I have a 2011 LLT with 97,000 miles and dealer just told me the check engine light is due to my timing chain. I thought timing chains last the life of the engine. Is it common to have to replace it at 97k miles? The car seems to be driving find as there isn't any noticeable performance issues.
Dealer quoted $2,500 and said it's honestly not worth it to get it done at this point because engines can sometimes have problems down the road and not run quite the same after changing the timing chain. Of course it's out of warranty. Thoughts on whether it's worth it to get it done? I feel like after having this car for 10 years, this is the beginning of the end. The start of major problems and wondering if I should cut my losses. I'm in the market for a new vehicle so the option to trade in is available but also want to keep it as I know they aren't going to give my hardly anything for it. Sorry for the rant just trying to get some input/feedback. Thanks.
10-27-2020, 06:06 PM | #2 |
I hadn’t had this problem,and I have 147k on mine,but the same engine but have seen others say they have had the same problem. Good luck
10-27-2020, 06:56 PM | #3 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Do you have a code reader? Dealer is liable to tell you anything...but the truth. If cars run fine other than check eng. light. Unhooking the battery will turn that off. See if it comes back...if it does,see what the code is via code reader...parts house will read it usually.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
10-27-2020, 07:36 PM | #4 |
Drives: 2010 1LT RS Build 3/2009 Join Date: Jul 2014
As suggested, read the code yourself P0008 is one of the well known timing chain codes. The LLT engine should not be run low on oil. I religiously checked and topped it off between oil changes. I just had the timing chains replaced on my 2010 at 155,000 miles. $2500 is pretty much the going rate, it’s a big job. The car is paid for and I’m hoping to get another 100k out of it. Good luck!
10-27-2020, 07:39 PM | #5 | |
10-27-2020, 07:43 PM | #6 | |
All this sounds expensive
10-28-2020, 01:48 PM | #7 |
Drives: 2015 Camaro Join Date: Aug 2018
The dealer is yanking your chain. Engines do run right after replacing the chain. Dealers do it all the time for paying customers. They want to scare you off so you might be encouraged to trade it in for something on their lot.
It's a big job, but if you have something to drive in the meantime, you can probably crank it out in about 2-3 days taking your time. I did a head rebuild and timing chain replacement on a 2JZ-GE and it took me about 3-4 days. I had no prior experience. I just took my time after getting the rebuilt head back from the machine shop and followed the service manual. Don't let them scare you off. Just take your time and double check everything. The 2JZ-GE ran like a top after I fixed it. |
10-28-2020, 02:10 PM | #8 | |
I think you're right about the dealer. I don't however trust myself to do the work myself so I'm currently waiting on a second quote from my other mechanic. The other part to these shenanigans is that I may have to replace the catalytic converter after getting a P0420 code. Sensor has already been change so something else is wrong. That's another $1500+ worth of work. Geeze, does it end.
10-28-2020, 02:36 PM | #9 | |
10-28-2020, 04:06 PM | #10 |
Drives: 2010 ss Join Date: Oct 2015
SOUNDS LIKE HE HAS THE V6.NOT THE LS MOTOR,BIG DIFFERENCE
10-28-2020, 07:08 PM | #11 |
Drives: Camaro Join Date: Jun 2020
After you have the chains changed do yourself a big favor and change the oil every 4-5k, run a good synthetic like Pennzoil Plat and check the oil 1 once a week and keep it full. I run 1qt over full, I'm @ 97k runs like the day I bought it. Even 1/2 qt low is going to hurt the chain life. The only lube the chains get is from vapor and splash, the lower the oil level the less slash and vapor lubing the chains. Only GM knows why they didn't properly lube the chains. I can only imagine they wanted plenty of work for the dealers. I know of some dealers that have wrenches that only change chains, that's their only job. No reason you shouldn't get another 100k if you follow my advice.
10-29-2020, 03:39 PM | #12 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
The chains (there's 3) cost more than $30, and if you can find some cheap chinese chains for $30 I would not trust them on my engine. Besides that, if you're going through all the work of changing the chains you might as well change the whole kit. Most people can't do the job on their own anyways, plenty of people would **** up their engine putting it together wrong. Not to mention you'll need coolant, gaskets, etc |
10-29-2020, 10:03 PM | #13 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I'm think maybe he meant $300. I did a quick Google check and found an entire set for just under $500 at Advanced. $2500 at dealershaft is not surprising. The LLT is an intricate machine but this could be tackled with patience. Maybe OP can find an experienced friend or a good independent shop to accomplish the repair. Only picture is a nice looking vehicle. Cars get old and things wear out and if I recall the timing chains were a problem component in the early V6 Gen 5s. Repairs may still be cheaper that a car payment in the long run.
10-30-2020, 04:29 PM | #14 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
Bank 1 cam/crank correlation code.
these timing chains stretch I've found that they stretch about a half a link These engines love timing chains chains, tensioners, guides That job pays 8 hrs Timing chain kit roughly $400 a reputable shop should be around $1300-$1500 |
