02-14-2024, 05:04 AM | #253 |
Drives: 1977 Trans Am, 2024 Camaro 2SS Join Date: Apr 2023
I checked my 2024 2SS, built 11/23, last night. Sadly, there's no PBC plaque.
-Ray |
02-14-2024, 06:29 AM | #254 |
It's a nice touch for sure, but there is no difference between these LT1s and the ones we have in our cars.
02-14-2024, 07:14 AM | #255 | |
Drives: 2011 GMC Sierra 1500 Join Date: Jun 2022
The parts are the same, its the assembly process that is the difference. Assembly line vs single builder. No Watches Allowed: Inside Chevrolet's Secretive Performance Build Center Even though the A10 cars are "quicker"(drag racing), the PBC engine and build process was one of caveats in deciding to go with a M6 car for my build. Also there was an poster here very familiar with the process and stated that even though Chevy was going to continue with putting PBC LT1s in M6 Camaros, the engines would not display the plaque. Looks like they did indeed phase the plaque out during the '23MY run.
2023 LT1 Coupe M6 - Black (GBA) on Black (H1T)
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W) LT1 PBC engine built by Shane Parker Current mileage: 310 Last edited by Junction65; 02-14-2024 at 07:25 AM. |
02-14-2024, 07:43 AM | #256 | |
For example, no one can manually torque 10-12-16 bolts down perfectly to spec simultaneously, which is the absolute best method for attaching parts like heads or the supercharger lid; at the same time, machines cannot respond to unexpected siuations or vary the process a bit to fix an edge case like a human does. To make this call correctly, we would need to see actual failure/trouble stats for both assembly types, and I'm not sure we ever will.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 02-14-2024 at 10:08 PM. |
02-14-2024, 08:20 AM | #257 | |
Miller Time Wisconsin
Drives: '24 VOM 1SS 1LE M6. 1 of 4 Join Date: Jul 2018
Location: Formerly USA, now planet of the apes bizaroworld
2024 1SS 1LE M6 rockcrusher in Vivid Orange Metallica. 1 of 4
02-14-2024, 08:38 AM | #258 | |
Is there a Perfect Engine Club for the assembly line engines?
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W) LT1 PBC engine built by Shane Parker Current mileage: 310 |
02-14-2024, 08:49 AM | #259 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
assembled doesn't mean hand built or certainly not balanced and blueprinted, I only took it as a bit of a novelty and certainly interesting but is one better than the other...in this context, no.
02-14-2024, 09:00 AM | #260 | |
Drives: 15 RH Z/28, 23 RB2SS1LE, 23LT1VOM Join Date: Dec 2012
https://www.camaro6.com/forums/showthread.php?t=579447 |
02-14-2024, 09:13 AM | #261 | ||
Dug up the old post I was referring to: PBC Engines Quote:
Each to his own...you don't have a PBC engine, good for you no worries. I wanted one so that's what I bought.
02-14-2024, 09:55 AM | #262 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Just wanted to state that the left over C7 engine rumor is definitely a myth. GM is a JIT manufacturer (Just in time) like all other major manufacturers. There’s no way they just had a stock pile of c7 engines that lasted from 2020-mid 2023. Even if they were for the c7 the engines are identical regardless outside of the intake tube and exhaust manifolds that are camaro specific.
I remember reading the bit posted above from the unnamed PBC engine builder. Personally I hope it’s true since I have a late 23 without the plaque but as with everything I read on the internet I take it with a grain of salt. Whether or not I have a PBC engine I know it’s in no way better than a non PBC engine. They have the same crappy afm lifters. I also feel like I’ve seen way more engine failures of 2020+ vehicles than 16-19 but I could be wrong about that. Based on what I feel I’ve seen on these forums, the precovid engines seem to be holding up better. 2020’s had a known valve spring issue. 21/22’s seem to have more lifter failures than the older engines. I know for the trucks they definitely have been having lifter issues on those model years. Hoping 23’s and 24’s are fairing better.
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
02-14-2024, 10:47 AM | #263 | |
02-14-2024, 10:59 AM | #264 | |
02-14-2024, 03:58 PM | #265 |
It is common knowledge the LS7 wouldn't be emissions compliant for the next gen of cars, GM had a few thousand sitting on pallets at Wixom with nothing to put them in. Then Al O convinced the brass to green light a hot rod parts bin track weapon,which took care of those motors. Not exactly an internet guess.
