02-23-2018, 12:24 PM | #1 |
Drives: Chevy Truck Join Date: Mar 2017
How long will a garage kept SS last putting about 5-10k miles a year on it?
Before you need to do major work?
02-23-2018, 12:29 PM | #2 |
376 cubic inches of fun
I have a 2010 with about 65,000 miles and it's garage kept.
It hasn't had any failures related to age or mileage. No leaks, and belts and hoses look to be in excellent condition. I also don't drive it when there's salt on the roads. |
02-23-2018, 12:31 PM | #3 | |
Drives: 2017 Camaro 1SS, 2023 Colorado Z71 Join Date: Sep 2017
I am also interested in this question.
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow |
02-23-2018, 12:46 PM | #4 |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
I don't take my ZL1 out when it rains. It should last a very long time. About the only thing could happen is rotting rubber parts.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
02-23-2018, 12:52 PM | #5 |
Retired from Car mfrs....
It depends on where you are. Are you near the coast, do you have salt air? If not, figure 10 to 15 years before you see any rubber parts starting to oxidize, much shorter if you're on the coast/beach..... if you could put the car inside in a air conditioned space like the Ferris Bueller Ferrari, it would last longer than you'll live… This is assuming that you also do all the normal maintenance on time, in the correct manner.
02-23-2018, 01:19 PM | #6 | |
02-23-2018, 01:40 PM | #7 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
I've had mine just over 2 years, I have right around 4100 miles on it. Store it from October till about the end of March with a cover/battery tender on it. I'm hoping mine will last to give to my kids.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
02-23-2018, 01:42 PM | #8 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
As long as you keep it maintained should 50+ years. My father in-law still has his 69 Z/28 he purchased in 1969 garage kept puts around he has just over 60k on the factory motor, factory clutch, factory everything.
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
02-23-2018, 02:00 PM | #9 |
Drives: 2017 Camaro SS Vert w/2SS Join Date: Aug 2017
The less you drive it the harder it actually is on some of the components, especially if you have lots of short trips where the car barely gets warmed up before you shut it off again like I do. My bad weather car is a 2011 Malibu with 45k miles on it (I drive about 5k total between it and the Camaro) and I just had to replace the water pump and a coolant hose because they were both leaking due to age, not mileage. The dealer was telling me if I put more miles on it or drove it more when I had it on the road the water pump probably would have lived longer. That's the first thing I've had to do to that car besides tires and oil in the 7 years I've had it though so all in all not a bad deal.
02-23-2018, 02:24 PM | #10 |
Drives: 21 Bronco Join Date: Jun 2012
How you gonna mention something like that and no pics!
02-23-2018, 02:32 PM | #11 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
As long as the garage is ventilated and the humidity is not too high ~60% it will never rost. Keep it away from the UV (direct sun light) and keep the rubber soft it will last more or less forever. If you drive it, drive it warm and longer distance.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
02-23-2018, 03:02 PM | #12 |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
It's hard to say. Others have valid points regarding climate and maintenance. However, there are electrical and mechanical parts on the car, which can go bad at any time, even with proper maintenance. Do a search for rear differential groan, as one example.
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
02-23-2018, 03:19 PM | #13 |
Drives: 1968 SS/RS, 2006 H2 2016 2SS White Join Date: Sep 2015
Major work~ 17.28 years
2016 2SS White fully loaded
02-23-2018, 03:20 PM | #14 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Longer, regular highway trips? Will last a long time.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
